3.5mm won't work with android?
Old 09-23-2014 | 04:38 PM
sigmashark's Avatar
Hello, this is my first post here.
I purchased my first Fit, a 2009 non-sport, about 5 hours ago, certified-preowned.
I've run into an issue where my girlfriends iPhone will work perfectly with the 3.5mm aux jack, but my HTC One will not. My HTC won't even recognize that there is anything plugged into the headphone jack. Now, I use the same cord for my headphones (wireless with an optional 3.5mm port) and it works just fine with my HTC. Any ideas?
Old 09-23-2014 | 04:53 PM
sultanofslide's Avatar
I have no issues with android and the 3.5mm jack in my car but I'm using amazon mp3 for music playback.
Do you have a case on the phone that may not be allowing the cord to seat all the way?
Is the internal volume of the phone turned all the way up with the cord plugged in?
Old 09-23-2014 | 04:55 PM
sigmashark's Avatar
I have a case on the phone, but as previously said, I have no issues playing with the case/cord/phone when I have it plugged into a different device. It's just with the Fit. And the music comes out of the phone, because it doesn't even recognize anything as being plugged in.
Old 09-23-2014 | 05:40 PM
revelat10n's Avatar
I would try a different cable or make sure both ends are fully plugged in. I haven't had any issues with my HTC Onx X+ or my older HTC Inspire with my Fit's 3.5mm jack.
Old 09-24-2014 | 01:41 AM
ingram10's Avatar
I've had no issues with an S3, note 2, and note3
Old 09-24-2014 | 02:24 AM
13fit's Avatar
so your phone and cable work with the headphones, the cord works with your girls iphone and honda, but your phone doesnt work with the honda?
You must not have had it plugged in all the way somehow, how else would the cable work perfectly otherwise?
the radio cant tell what is plugged in, it just wants to get a signal to play audio.
Old 09-24-2014 | 02:48 PM
4thCornerFit's Avatar
My Android works, but the plug-in order makes a difference. Try plugging the cord into the phone first, then the other end into the AUX port. If that doesn't work, plug into the AUX port first, then your phone. See if this makes a difference.
Old 09-24-2014 | 02:53 PM
i dont usually plug my phone to the aux jack since i have BT, but ive tried it with my droid and it worked fine.
Old 09-25-2014 | 09:51 AM
Newtownguy's Avatar
I have the exact same phone and verything work for me
Old 09-25-2014 | 10:01 AM
sooznd's Avatar
Have you tried plugging in via the USB cable in the upper glove box & not the aux port?
Old 09-25-2014 | 02:04 PM
dpmason's Avatar
My HTC One works great in the FIT via the 3.5. I do somtimes have trouble with the HTC side of the cable. It can be a bit tough to get it fully seated, especially when the phone is in its case.
I ordered a quality cable from Belkin which has very slim pugs, problem solved.
Belkin MiXiT cable Belkin MiXiT cable
FitFrack
04-08-2016 01:39 PM
Desmond Lamar MacRae
11-15-2014 04:35 AM
Red 05
11-10-2011 07:27 PM
Giggles
08-21-2008 06:34 PM
loganjnt
07-30-2006 01:57 AM
