Wheel Alignment - Front only or four wheel?
Even the Helm's manual - bought so impetuously and at great expense - doesn't specify. It gives the settings for all wheels but I still find no specific directions to check/adjust rear alignment for my Base 2012.
What has been your experience and current advice, please?
Thanks.
Thanks.
np. if you buy camber bolts for the front (SPC makes them), you can do the toe and camber. i have the spc bolts i bought from tirerack. works great, dialed in at -1.5 degrees, zero toe-in for my swifts with RE760 tires.
knm345
04-12-2013 01:45 AM
matrix02
09-08-2010 01:10 AM
