Front seats un-Fit for long trips
They aren't that bad for short trips, but on long drives my butt gets very sore from sitting so long. I recently took a 700 mile trip, and boy was I sore long before I arrived after almost 12 hours! Specifically my right rear end from pressure on the seat. Actually sat on a pillow for most of this trip, helped a little, but a poor solution for the problem. Simply not enough cushioning, ergonomics not that great. No seat adjustments helped.
Thinking of having the fronts reupholstered with new foam and possibly switching to a fabric surface instead of the vinyl. What can be done to improve the seat comfort beyond this, ideas?. I don't have cruise (base '09 Fit) but that wasn't bothering me like this was. Sooooo uncomfortable.
Three things -
1 - remove wallet from your azz
2 - add a couple washers on front seat bolts to raise seat front. One or more washers.
3 - add spring to gas pedal to stiffen it up so you ar enot holding foot up all the time. This was major problem for me.
Spring - https://www.fitfreak.net/forums/2nd-...rn-spring.html
Three things -
But yeah, the seats are a butt-bind after 8 hours on the road. I want seats that kiss my butt; the Fit's aren't it.
I'm looking into options to make the seats more comfortable too. I'd like some lumbar support options.
1. I found a 3-in-1 heat/cool/lumbar support option on ebay for $50 bucks. I ordered it and will test it out this week or next. The lumbar massage looks cool.
2. Buckwheat cylinder shape pillow. I bought one of these off ebay and I like it, just a little too big for it to comfortably be behind me. I might have bought the neck version. Didn't want to open it up and rebuild it to suit my needs but I keep it in the car and use as arm rest.
3. What I'm using right now is just a rolled up kitchen towel. I get pretty good comfort out of this. If the 3-in-1 doesn't work what I'm going to do is get the appropriate kind of towel and roll it up, then i'll hang it from the headrest so I can place it in the desired spot. Also thought about a small section of wood beads placed in lumbar area too.
Hope that helps. Let us know if you find any cool options.
I just got back from a long trip myself (drove out to Quebec for ROCK FEST!!!)
was about 7 hours stopping every 2 or so hours for a stretch break
it wasnt so bad for me.
cant wait till next year to do it again.
I'm using this too. My chiropractor told me to take a long tube sock (like goes up to my knee) and stuff a towel in it, and that did the trick. I was having all kinds of back pain, no matter what I did, and the sock worked. Have driven for 2 hours and no problem.
The Fit's great for road trips. I went from Toronto to Ottawa at the beginning of May and loved the open highways and of course the rest stops
I always store my wallet in the top glovebox, pockets empty. And I do stop at rest areas and walk to stretch, and at fuel stops. But just the length of time having to sit is not good on these seats, no matter what. I'm average size, 175# 5'8". I did use a soft bed pillow, made it somewhat better. Around town it's OK. Thinking about another couple of posters mentioning Civic Si seats, and Recaro. Try not to be extreme with it, but certainly want a softer more supportive ride that doesn't leave me sore on long drives.
Thanks for pointing this out. I'm looking to pick up a Fit for my daily driver to replace my 16 year old Civic, and love the fit for its mix of small size, great gas mileage, and impressive cargo capacity. I sat in a GE8 at a dealership, and noticed that the driver seat didn't slide back as far as I would like, but I didn't pay much attention to the density of the foam used in the seats, or the lumbar support.
Yeah, I'm gonna pop over to my local Honda dealership here this week and sit in one to get a good feel for the ergonomics, possibly even take it for a test drive. They only have 2 2013 GE8's in stock, so I better get over there quick before they're gone!
Three things -
^^ wat black3sr said. i can go in my MT GE 200+ miles non-stop and back
another 200 miles non-stop same day with absolutely NO fatigue or pain thanks
to black3sr's recommendations.
Got the seat cover and seems pretty neat. Looking forward to using it on my drives into work. Some immediate things I noticed:
1. Good static lumbar support as-is, even without the massage feature turned on. Don't expect a shiatsu style massage but it does buzz around on Low/High.
2. Cooling (Fan) actually works pretty good with more flow than my old Lexus LS430. Could feel a nice breeze in the lower back side :-) Fan motor is pretty loud so if you have it on High you probably need to crank up the music.
3. I haven't tried the Heat setting because it's just too hot outside. It doesn't use the fan/motor so no worries about the noise.
4. Made in China but the packaging has both English and Japanese so hopefully it will last awhile.
Remote control and pouch is a nice touch
Seat fabric matches the Sport interior pretty well. You can see the lumbar support at the bottom, pretty firm.
Fan motor dangling
Not too bad! You also get a little lift up toward the front cushion due to the padded surrounding.
Fan motor dangling
Even after 3 back surgeries and half a decade in the Army, my Fit seats are still feeling comfortable to me.
Even the slightest seat adjustment might make a positive improvement. Play with the seat a bit. lean it back a tiny bit and move it slightly closer or something.
I havent ever owned a Honda where the seats were not up to feeling good. Loved the Recaros factory in my Del Sol
Chairman Kaga
09-04-2011 12:12 PM
