Another wheel question from another newb. Lil help?
Old 06-19-2014 | 04:37 PM
GoJaskill's Avatar
So I found some wheels in a style I like on the ol' Craigslist, and I'm wondering if they'd fit my Fit – and also how hard finding tires would be.
Here's the size:
17 x 7.5 4x108
The wheels are OEM Ford Racing wheels in white. They're cheap, and I think they'd look mean on my Vortex Blue 2012.
Explain like I'm 5 years old how this will or will not work? And if it will, where would you recommend I shop for tires?
Thanks so much!
Old 06-19-2014 | 04:57 PM
ROTTBOY's Avatar
Am sure the more learned will chime in but its gotta be 4x100 at the very minimum.
Old 06-19-2014 | 05:14 PM
Frenzal's Avatar
Bolt pattern is wrong on the wheels!
You need a bolt pattern of 4x100 to fit the spacing between the studs on the car.
With a 4x108 bolt pattern on your wheels, you won't be able to fit them on the car.
Bolt pattern info (4x100):
-4: 4 bolts on wheel (4 studs on car);
-100: spacing between the studs (I think it is the diameter of the circle that would fit on all studs)
I typed too much! Just look here as they have the right words : http://www.tirerack.com/wheels/tech/....jsp?techid=92
Old 06-19-2014 | 05:24 PM
GoJaskill's Avatar
Thank you sir. The dream is dead!!
Old 06-19-2014 | 05:48 PM
lol'ed....
10char
Old 08-19-2018 | 03:02 PM
upallnight's Avatar
better that the dream is dead, then the nightmare begins. LOL
Old 08-20-2018 | 05:29 PM
Goobers's Avatar
Necroing a 4 year old thread?
Old 08-20-2018 | 08:14 PM
evilchargerfan's Avatar
sweet thread revival!!!
Old 12-21-2018 | 07:51 PM
Brain Champagne's Avatar
You'd be buying the second half (the worst half) of a car's life for more than half the price of a new car.
It used to be that used cars were a bargain because a car lost a third of its value the day it was driven off the lot. Now it seems like the opposite- used cars are more expensive than new cars relative to the remaining life.
And given how bad dealers are at the pre-delivery inspection on new cars I wouldn't have a lot of faith that their 100 point check was any more than a guy with a pencil seeing wheels and checking the box that the brakes work.
Old 12-22-2018 | 08:29 AM
upallnight's Avatar
Sono
06-09-2017 12:01 PM
y950129
03-01-2011 08:03 PM
konespeed
07-19-2010 02:36 AM
HONDAJUNKIE
10-27-2008 08:34 PM
DrDiff
03-21-2007 12:18 PM
