How often do you change your oil???
Old 03-26-2014 | 05:09 PM
13fit's Avatar
For automatics, a cooler will do more good then using any fancy fluid
  #62
Old 03-26-2014 | 08:48 PM
2010FitSport's Avatar
Agreed! Coolers can prolong trans life by keeping fluid temps from getting too hot.
  #63
Old 03-27-2014 | 10:54 AM
fenderfatstrat6's Avatar
I am excited to try full synthetic and see what mpg change I will get
  #64
Old 03-27-2014 | 10:57 AM
Steve244's Avatar
If it's more than 1 mpg the difference is due to placebo effect. Controlled lab studies put the difference at 3% (sorry don't have a link).
  #65
Old 03-27-2014 | 08:06 PM
spreadhead's Avatar
The performance increase is about like switching to premium gasoline, none!
  #66
Old 08-24-2024 | 06:56 PM
irontmp's Avatar
Originally Posted by raytseng
Tire rotation is not exactly a safety issue.
It's a financial issue just to save money for the frugal consumer.
From a performance perspective, keeping the tires where they started will wear them in in their natural rotation, so the are actually the "safest" where they started (until you reach the tread limits).
Here's a thought experiment, High performance sports cars have corner specific tires blog, there is no rotation for them.
For the fit, Front tires tend to wear the edges/shoulders more; rear tires the center.
front tires wear about twice as fast as the rear.
If anything as far as safety, when you rotate your tires, they actually have less of a contact patch so and take time to rewear down the high edge of that tire to be a fuller contact patch.
The longer you wait, when you finally do the rotation, there is the most difference in the tires from true-round , so there is a biggest difference to rewear down to fit the natural alignment of the new corner.
But it's not really a true vital service or if you do not rotate tires, it is just you may reach the min tread at a section of your tire faster. There are other checkpoints of a tire like if it's starting to get hardened old and cracked, the PSI and treaddesign and treaddepth which are far more important to overall safety.
As for what I do; for my first set of OEM tires, I just rotated once, when the fronts were about 50% (backs were about 75%).
Then when the new fronts were about 25% the backs were also about 25%; i said time to switch to continental dws, these tires are getting hard and crusty.
For my current pair of dws, these are treadmarked with DWS. I plan to wear the fronts until the S goes away. Then switch the lesser worn rears (which still should have S showing) to the front for the next winter season until those S's go away.
Then finally time to replace when i only have Ws left at the start of the subsequent winter.
Many on this list prefer to do oil changes at 5,000km which is half the recommended interval. For those that do this; Do you change the filter every second change and do you also do the gearbox and drive oils at the same time?
  #67
Old 08-24-2024 | 07:49 PM
56chevydan's Avatar
I really can't remember ever seeing a post resurrected after 10+ years......
Automotive engine oil technology has really made great strides in both snthetic vs conventional oils- especially over the last 10 years. I would ignore what members did for oil changes 10 years ago and look on the internet for published info on what the petroleum companies are publishing for recommended oil change intervals. Current info should also be researched from oil filter manufacturers as to how many miles oil filters can go- especially with synthetic oils.
Just my two cents worth.
  #68
Old 08-25-2024 | 12:16 PM
Mister Coffee's Avatar
@irontmp I change my oil and filter very 3,000 mi. I use Amsoil 0W20 Full Synthetic and a Honda OEM oil filter (the ones that are made in Japan).
bach
08-24-2016 09:32 PM
FlipsFit
08-19-2011 11:32 AM
dexterousdeven
08-20-2010 06:50 AM
Lynn
06-15-2009 05:03 PM
mole177
02-16-2009 01:19 PM
Quick Reply: How often do you change your oil???
