17x7.5 will they fit on ge8
I want to run a 17x7.5 on my GE8 and was wondering if it was necessary to run spacers to clear anything.
http://img130.imageshack.us/img130/949/grb0007.jpg
Should not be a problem at all in the rear. In the front you will need to add some camber if you dont have any already.
I personally run a 17x7 +42 with a 5mm spacer in the rear and I am pretty flush in the front tho I have no neg camber yet nor am i slammed on coils yet either.
I'm running 17x7.5 low 40ish offset on 205/40 tires with no issues. Running -1.7 camber both sides with my fender liners tucked. Lowered on tein basis coil over, all the way down in the front and pretty low in the back.
![Talking](https://www.fitfreak.net/forums/images/icons/icon10.gif)
are you running a separate camber kit and if so where did you get it so I can start looking
SPC and Eibach as well as others have the bolts available.
Thanks Ill look for them
Sounds good I was looking at picking up a camber kit for the front and rear anyways. Thanks for the info its all really helpful
Thanks I'm still looking at camber bolts and shimes still want to fine the camber issues to make the wheels and tires look right
I'm slammed right now on form and function type 2s on the stock sport wheels, but I'm looking to raid it up a little when I put the new wheels and tires on.
are you running any spacers on the front or rear? good to know about the roll and pull.
![Confused](https://www.fitfreak.net/forums/images/smilies/confused.gif)
