Driver Seat Floor Mat moving around
I got my fit today, and long story short, I put my old Canadian Tires mat on, and i has a hard things and i won't stick, what should I do? should I tear that annoying hard floor mat out? I don't want to pay 150 for the whole things...
I have the same problem! When i bought my fit she came with mats that say "FIT", YET THE KEEP SLIDING! I tried two way tape with no luck, now im going to try velcro
Edit:tell me any solutions you might have!!
how about you punch 2 holes in the universal mat and tie it to the seat rail anchors using a zip tie or some string or strap?
or just get the right mats before you cause an accident.
I use pletiful strips of carpet double side 2' tape; haven't had much luck with velcro.
Stapling just the staple without 'folding' worked too and surprizingly removed and reinserted pretty well.
I had the same problem with my drivers side mat, tried velcro also tape both of which did not work.
Finally used an office clip (that you use to hold a bunch of papers together) and slid it thru the rail under the seat and cliped it onto the mat. Works perfect.
OEM floor mats are around $70 so no reason to be cheap when it comes to floor mats, they last a long time so you might as well be running what was intended for your car:
Or since you're in Canada you could also go for the all seasons:
CJfit15
09-09-2015 02:22 PM
