M/T rpm doesn't drop enough when shifting
Old 04-16-2013 | 02:48 PM
Steve244's Avatar
Originally Posted by DavefromCA
I purchased a 04 Mach1 mustang that was also a stick and I had the same complaint. I learned to live with it however here is the Mach 1s procedure for fixing the issue. No clue if this would work on the Fit but it appears that it has to do with the IAB valve.
Hanging/Slow dropping RPM FIX inside. - 2003-04 Mach 1 Registry Owners Club
Fit's don't have an Idle Air Control valve (IAC) with drive-by-wire and using the throttle plate to control idle. So, no, this mod doesn't apply here.
The only way would be to reprogram the Fit's ECU removing the logic that creates the throttle hang. This has been done for older generation Fits but not ours. And it will fail emissions tests in major metro areas and the state of CA (not to mention void your warranty).
Honzo
05-04-2017 09:18 AM
Fitftw15
11-10-2015 01:33 PM
royalflush313
02-18-2011 10:43 AM
Joe_Schmoe
08-03-2006 06:53 PM
jim beam
06-13-2005 03:26 PM
Quick Reply: M/T rpm doesn't drop enough when shifting
