How to disable VSA (traction and stability control) without TPM sensors installed.
Old 04-08-2013 | 03:24 PM
FitStir's Avatar
Thumbs up
^^^I don't think they did the MAC support.... but you can just that program, and run Win7 from there.
I'm a MAC user too.
Originally Posted by x_25
Raceway park in oldbridge! Went to the road course school to get my track day license there. I have no hope of keeping up with the regulars as such an inexperianced track driver, in fact, the idea of running with those guys scares the **** out of me. ....
Gotta look in to that... I was looking at the track in South NJ. Thanks.
Old 04-08-2013 | 03:35 PM
I'm a MAC user too.
sounds good. i wanted to ask you... does the unit do multiple cars, or is it based on one car?
or do i just make another folder in my computer and 'add' a car, or ..??
i own 4 cars that run tpms so i want to be able to swap between different cars if i ever buy the unit.
Old 04-08-2013 | 03:57 PM
FitStir's Avatar
I haven't tried it yet, since I only have 2 sets to swap, but I've read for other users they have the program set up on different flashdrives and that will allow you to set it up with as many cars as you have. It might work in the different folders as you mentioned, but I haven't tried that yet.
btw I forgot the name of the Mac program, but I guess you know what I meant & you have to install Win7. I can take a look when I get home... for the life of me it always slips my mind.... I tell ya one thing, I never seen Windows run so fast as it does on a Mac...
oh, and as an FYI there's a seller selling 4 TPMS sensors for ~70 on ebay, and they work with no issues as reported by other Honda owners... you do have to have the shop install the washer, etc... but a lot less expensive than the OEM ones.
70 for the sensors + 150 for the ATEQ = 220 for unlimited tire swaps... the savings is much more if you have multiple vehicles or wheel set ups.
Old 04-08-2013 | 04:31 PM
Old 04-08-2013 | 07:24 PM
Cliff's Avatar
As far as the track testing, every time I have had the ASM kick in, it's been fairly violent about it, and the car did nothing unexpected/violent on the track.
FWIW, on the track you're better off disabling VSA. Leaving it on will cause the car to brake or mess with engine speed to recover from some microprocessor-perceived loss of traction issue that may be intentional on your part and ultimately upset the balance of the car. I autocrossed my car yesterday with VSA off and it was rock solid.
Old 04-08-2013 | 09:31 PM
x_25's Avatar
I meant every time in the past it has kicked in. I had it off the whole time I was on the track.
I will say, that braking on an uneven surface (they are repaving the track this week) from 80mph, into a left hander, made the car shimmy quite a bit. Need to figure out why.
Old 09-10-2013 | 01:02 AM
07fit916's Avatar
Sorry to bump an old thread but has anyone else tried this and have it work?? I just tried it on my 2013 Sport and after about 2 miles vsa is still on.
Edit: oops. Saw the 10 mile thing. I'll try again
edit: vsa still on at 10 miles and 20 miles.
Old 03-03-2018 | 01:17 PM
Keali'i Pomaika'i's Avatar
sorry to bump your bump 5 years later lol but did it ever work for you? Mine hasnt gone off either
Old 03-04-2018 | 01:50 AM
07fit916's Avatar
Doesn’t work on 12-13. You can disable vsa AND abs though by just unplugging the abs module under the hood
Old 03-04-2018 | 02:47 AM
Does unplugging the module work on the 12-13 fits? Or is it only for prior years, and will it work normally if i plug it back in
Old 03-04-2018 | 06:38 AM
spike55_bmw's Avatar
I'm probably missing something but my '11 Sport AT has a dash switch to deactivate the VSA but ABS still works.
  #32
Old 03-04-2018 | 06:52 PM
yeah, but my problem is that i dont have tpms sensors in my new rims and you cant disable vsa unless you have synced sensors wich really sucks for me cuz my fit is auto and my stick car is down right now and i was hoping i could get a small spin out during the rainy season lol
  #33
Old 03-04-2018 | 09:03 PM
I had assumed the opposite: If the TPMS system not working and/or wheel sensors not working / installed at all then the VSA would not work and the VSA Warning Light coming on indicating the the system is disarmed.
The way I think about it (might totally be wrong) is that VSA is monitoring the difference in RPMs between the front drive wheels to determine if one is spinning faster that the other because it has lost grip. Then the VSA system applies the brake to the faster spinning wheel, so power is shifted the wheel that has grip. The VSA automatically gets disabled if the TMPS system isn't working (dead sensors or no sensors on wheels) because one wheel could be spinning faster than the other simply because there is less air pressure in one tire than the other, and therefore smaller diameter / spinning faster.
  #34
Old 03-04-2018 | 09:41 PM
07fit916's Avatar
Should work on all 09-13. And it should work normally when you plug it back in. But don’t blame me if it doesn’t for some reason lol. I’ve done it a few times though.
  #35
Old 03-08-2019 | 02:15 PM
whitefitsport's Avatar
Where is this plug? Could someone show a pic just to be sure?
Another thing that might work would be to swap some 2011 parts onto a 2012 right? Does anyone know what parts need to be swapped for VSA to be off without TPMS? Please help! I really cannot have VSA for track days
  #36
Old 03-09-2019 | 09:29 PM
Found some solutions
So I did find the module plug. It's pretty big and a bit intimidating to unplug but I tried it and went out for a drive and it seems to work. The ABS and BRAKE and VSA lights will stay on.
Even better news is Tirerack offers TPMS for wheels now! So 2012+ owners can have VSA off while still having ABS with aftermarket wheels
  #37
Old 03-14-2019 | 06:37 AM
whitefitsport - That engine bay looks clean enough to eat off of. My aluminum is all cover with spots from wet road salt spray (Pennsylvania). Curious, as noted earlier, I can toggle my VSA switch off/on with the '11 Sport. I'm assuming that whether VSA is off or on, the ABS system is still working. Is that wrong to assume? Also, what changed in those systems between 2011 and 2012+ models? Thx
  #38
Old 03-16-2019 | 06:09 AM
Haha thanks! I just bought it recently and everything is like brand new! It had 1 previous owner who really babied it and has only 27k miles
You're right about ABS still working whether VSA is on or off. The only difference between 2011 and 2012 models comes in play when TPMS is gone. There is a way to disable just VSA in the pre-2012 models by disconnecting the plug behind the VSA button, but that doesn't work for the 2012+ ones for some reason.
Chriscopp
10-06-2010 10:32 AM
kmschwem
03-27-2009 09:17 PM
90crxfreak
03-03-2009 04:15 AM
txmatt
01-03-2009 12:15 PM
cranky18
12-20-2008 08:35 PM
