No Deceleration When Braking
Old 03-06-2013 | 10:44 PM
linowza's Avatar
I'm not really sure how to describe this issue... Occasionally, when I'm coasting downhill at high speed and then I apply the brakes, the engine continues to rev at, say, 3000 RPM, and it's a bit jarring. The engine continues to run as if I never applied the brakes (though the speed of the car decreases).
Hope that makes sense or sounds familiar.
I have a brand new Fit Base AT.
Thanks.
Old 03-06-2013 | 10:55 PM
DrewE's Avatar
It sounds perfectly normal to me. The car doesn't shift itself into neutral when you apply the brakes—it stays in gear, providing some amount of engine braking. Some automatic transmissions will even downshift when the brakes are used under certain circumstances to give additional engine braking; I don't know if the Fit's does this or not.
Old 03-06-2013 | 10:58 PM
linowza's Avatar
Thanks Drew. It seems like it's probably normal, like you say... I just don't know why I've never noticed it before with any other cars I've had. Maybe because it's my first NEW car, so I'm very aware of everything. :-)
Old 03-06-2013 | 11:32 PM
connor55's Avatar
When I coast at high speeds downhill my fit down shifts automatically to provide engine breaking.
Old 03-08-2013 | 10:14 PM
Steve244's Avatar
The AT has grade logic and is programmed to shift down (increasing RPM) when you apply the brakes on a downward slope. The engine is helping slow the car.
Sorry for the crappy screen grab
Jisch
06-22-2019 11:17 AM
Oneoldphlaytis
09-09-2014 09:24 PM
fito08
08-15-2014 04:39 AM
jfw432
09-20-2013 10:36 PM
hqly
09-06-2006 03:20 PM
Quick Reply: No Deceleration When Braking
