HELP - Recycled/Cabin Air Lever Stuck
Old 03-17-2020, 10:38 PM
Yoyojomo's Avatar
@john21031 That was it! After seeing that your plastic piece coming from the switch was actually inside the plastic piece attached to the flapper door, I realized mine was not. I bent it a little to get it over the flapper's plastic piece, and it finally snapped back into position and now works perfectly. Can't thank you enough! Thank you for taking the time to record the video as well. Really appreciate it. 🍻
Old 03-18-2020, 05:48 AM
john21031's Avatar
Originally Posted by Yoyojomo
@john21031 That was it! Really appreciate it. 🍻
Awesome. Glad to hear it solved your problem.
Happy to help. That's what the forums are for
Be safe there with the virus and enjoy the FIT.
Old 06-08-2020, 11:47 PM
Joe0709's Avatar
I just now joined the forum so I could thank everyone for their answers to the above issue. I also was experiencing the 1/2 travel of the fresh/recirculate lever. Checked to see if the pin had pulled out of the track, no, that was fine. So... I pulled out the cabin filter and found a large nest of insulation and acorn shells on and above it. This is a car that I don't drive often, and the rodent took advantage of that fact. On the plus side, the lever works perfect now, but, I feel the need to spray some disinfectant or something up the air passageways, yuck.
Old 06-09-2020, 09:46 AM
Yoyojomo's Avatar
Welcome, Joe! Agreed, there are a lot of knowledgeable, helpful people here. Like john21031 posting the video above... that's above and beyond. I've had two problems total solved already from their help. Cheers!
Old 04-11-2022, 10:25 PM
joeclark's Avatar
Just another user chiming in with how helpful this thread has been, especially the videos. I was having the same issue with my 2013 Fit Sport. I accessed the linkage and just helped it through one closing cycle and now it works fine on its own. (That is, nothing seemed amiss or loose.) A tool-free 5-minute fix! Thanks!
Old 04-11-2022, 10:44 PM
Yoyojomo's Avatar
That's awesome, joeclark! Glad you're here. Just ignore users like Goober above. A real black eye to any online community. But others are so helpful. Thank you to those who have given your time for the rest of us! 👍
Old 08-17-2022, 06:41 PM
FS2011's Avatar
Huzzah!!! This has been bugging me for years and I finally got fed up with the problem to google it and see if someone else had solved it. I had the same issue as pointed out in the videos. The lever had popped out of it's track.
Just registered to say thanks for posting!
fittyfit
05-22-2016 07:57 PM
KikeDiaz
06-15-2015 04:41 PM
vanzilar
10-13-2013 04:07 AM
ecofuture
09-09-2013 03:26 PM
2K8SPORT
07-29-2008 05:30 PM
Quick Reply: HELP - Recycled/Cabin Air Lever Stuck
