Wheel spacer recommendations?
Old 02-28-2013 | 03:55 PM
A-Diggy's Avatar
Any recommendations on spacer kits for an 09 Sport with stock wheels, tires and springs?
I've searched the forums, but seem to only find info on spacers combined with aftermarket wheels and lowered springs. I'm not planning to change my height (SF steep grade changes) or new wheels (yet). Just looking for the wider stance and look without rub.
Thanks for helping out this nOOb :-)
Old 02-28-2013 | 03:57 PM
Wafulz's Avatar
BUmp i want to know this too i wanna bring my rear stocks out more they look all tuck
Old 02-28-2013 | 05:06 PM
mkane's Avatar
Without a load from what I gather 15mm rear/ 10 front
Old 02-28-2013 | 05:23 PM
ThEvil0nE's Avatar
friendly safety reminder... anything bellow 5mm slip-in spacer will do but anything over that, you want bolt-on
Old 02-28-2013 | 05:33 PM
A-Diggy's Avatar
Thanks guys - only additional load would be from 2 bikes on the hitch rack. I'll def go bolt-on.
Old 02-28-2013 | 05:39 PM
ThEvil0nE's Avatar
I'm not sure what the offset is on the stock wheels but if you can get that... you can space it out to +42 and you should be good
Old 02-28-2013 | 06:22 PM
Mini_Odyssey's Avatar
You can easily run 20-25mm spacers on the back with stock wheels and 10-15mm in front. My Kosei wheels are 29mm more aggressive then stock wheels are they don't rub even loaded with 800lbs of Costco water.
Old 02-28-2013 | 06:45 PM
Wanderer.'s Avatar
with a 15mm bolt on spacer in the front do the studs stick out above the surface of the spacer or is it below the surface?
I don't want to shave studs but if that is the case I guess extended studs +10mm slip on it is.
Old 02-28-2013 | 07:02 PM
The proper way to do it is to use a hub centric spacer that comes with longer hub bolt studs you have to press into the hub. I don't recommend adapter style spacers that have studs pressed already in for that reason above alone. You would need at least a 20mm spacer for the hub bolt to come flat with the hub surface.
Old 02-28-2013 | 07:06 PM
Grab a ruler/tape measure.
See how many inches/fractions of inches you have to gain.
Multiply that number by 25.4
Order that size spacer.
Order new, longer wheelstuds.
Old 02-28-2013 | 07:24 PM
You mean divide that # by 25.4 so you can get it in mm, otherwise youll have a huge ass spacer lol.
Old 02-28-2013 | 07:41 PM
No.
1 in = 25.4 mm
1*25.4 = 25.4
If there's 0.5" gap, 0.5x25.4 = 12.7 mm
Old 02-28-2013 | 07:46 PM
No.
1 in = 25.4 mm
1*25.4 = 25.4
My bad bro, i was looking at the math backwards ahaha.
Old 03-01-2013 | 02:45 PM
Dookoo's Avatar
I went with Ichiba Hubcentric spacers 20mm front and 30 mm rear with Swift lowering springs. No rubbing rear but the front rubs occasionally on harder hits. Looks very flush.
Old 03-01-2013 | 04:34 PM
BakedCookies's Avatar
Cant beat H&R hubcentric spacers, I highly recommend them. You need to install the included longer studs as well.
Old 03-06-2013 | 12:19 AM
jondotcom's Avatar
just remember that most shops will often not re-install non-factory spacers because it is a liability for them. I was at a tire shop yesterday and heard them talking about it.
Old 03-14-2013 | 08:46 PM
A-Diggy's Avatar
anyone know if the stock wheels on an 09 sport have the recessed area on the back...so we don't have to shave down the existing studs?
Old 03-14-2013 | 10:34 PM
Dookoo's Avatar
My 2012's do. Take em off and look
Old 03-14-2013 | 10:39 PM
shortstop's Avatar
anybody have pics of these installed? I was actually thinking about it today. Also when are extended studs neccessary
Old 03-19-2013 | 06:03 AM
Golfer's Avatar
... Im with this guy
