Audio system code
^^ That if the sticker is there on the outside or inside of the glove box. Not all techs put the sticker in place during Pre-Delivery Inspection. Other places it should be is in your service history booklet and your radio code card if you have the package of booklets that came with your car from the factory.
If you do not have any of these, turn your radio off (where ENTER CODE will not show) then press 1 and 6 simultaneously then press the power button. There should be a code that pops up, its the serial code to the radio. Write that down and call/go to Honda with this and they should be able to pull your radio code.
john21031
02-23-2020 06:19 PM
