check engine
check engine
i changed the interior light bulb , and there was a shortcut , the radio,the interioir light and the central locking didht work . I found a burned fuse changed it. now there is a check engine light and the esp light ......what do you think happened , what can i do ?
tnx !!
tnx !!
and a word of advice. Enter the code into your cell phone to always have it with you. What if you were on a road trip and the code was 1,500 miles away at your house. That would be one long and quiet drive hiome.
_
I still don't understand why our radios need a lock code. If you steal one, you deserve the subpar audio quality that comes out of it. LOL
Good tips for the code but the op is showing a code error and not enter code. I think that by pulling the ECM fuse or disconnecting the negative battery lead should clear the fault and allow him to enter the radio code.
If that's true and the radio won't let you enter the code I think this is your best bet.
tnx for the tips ! i found the code and the radio is ok , now the last problem is the light of the dashboard that became not so bright like before , but when i turn the headlight off the dashboard brigtness is back .....
_
where can i adjust the dimmer switch ?
kitenok
12-10-2015 07:28 PM
Rob22315
08-30-2015 08:29 PM
