sport mode gear indicator blank initially
Old 01-15-2013 | 05:30 PM
2012fitnc's Avatar
Hi freaks,
I've been enjoying my 2012 fit sport for about a year now. I love the sport mode, more so for driving slow than going fast, and just all-around being in better control of the car. Anyway here's my question: the display does not show the current gear after I shift to sport mode, ie m1-5, until I hit the paddles. Is there a way to change this?
Old 01-15-2013 | 05:45 PM
Wafulz's Avatar
mines does that to u got to engage it
Old 01-15-2013 | 10:56 PM
kgb4187's Avatar
Only shows the gear you manually select.
Old 01-16-2013 | 07:50 PM
hogwylde's Avatar
After you shift into "S", it will stay blank until you engage it with the paddles.
Old 01-16-2013 | 09:54 PM
B Fit's Avatar
Makes perfect sense ............................. pick a gear
Old 01-16-2013 | 10:50 PM
Subie's Avatar
Originally Posted by 2012fitnc
Hi freaks,
Uhhhh I think that's a Honda Engineering and Design question...
Old 01-17-2013 | 02:48 AM
BraytonAK's Avatar
It does this because only putting the gear selector in Sport mode will cause the transmission to have a different range of shift patterns. It's useful in hilly terrain. Once you pull one of the paddles it will be in "manual" mode.
Old 01-17-2013 | 02:55 AM
FittedOnEm's Avatar
As everyone else said, you need to actually tap the paddle to engage it into the full "manual" mode. Just a side note - if you're in 4th or 5th and throw it into sport it'll hold in 3rd until you make a shift or put it back in drive. Taking off it'll do the same - 1st, 2nd, then hold 3rd.
Old 01-17-2013 | 02:58 AM
BraytonAK's Avatar
Oh, and you can start out in second gear using Sport mode, too. Useful if you're on ice. While stopped, put it in Sport mode then use the upshift paddle to engage 2nd gear. After a moment the transmission will shift. When you step on the gas you have less torque so as not to break traction.
nittany
11-19-2014 07:12 PM
Santiad
09-15-2010 07:27 PM
ozman
07-06-2009 02:02 PM
mozarwasagenius
04-06-2009 05:35 PM
hqly
08-19-2006 09:44 AM
Quick Reply: sport mode gear indicator blank initially
