Adding wheel audio controls to base model?
Is it possible to add the steering wheel controls? I would assume the wiring is probably there on the base unit, just no wheel control set, etc.?
If some one has done this, are there any threads with directions?
Thanks,
Thanks,
Depends on what year you have i believe. i think the 2012 models added optional steering wheel controls, so the wiring would possibly be there if you disassembled the wheel (remove the airbag, pull the black plastic mesh pieces from the wheel) I would research what the new models have on the wheel, and see what all changed.
I think you may run into compatibility problems tho with the plastic inserts (new controls) that would replace the blanks in your current wheel. all i have on my 09 GE8 is cruise controls on the right so
Thanks guys, your helpful links led me to this thread: DIY Steering Wheel Audio Controls (click here)
I may give this a go when I get my gps unit.
zeniitti
08-31-2017 03:34 AM
wackyflik
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
16
06-17-2017 07:32 PM
tonkatsu
06-26-2013 07:12 PM
