HID question
I currently have the bi-xenon setup in 35 watt it's completely sufficient. I have it hooked p with indepedance wire harness and relay directly to battery so it doesn't depend on the factory wire for power. The best brand I've dealt for for all my vehicles and bikes for reliability was DDM tuning. They make the most reliable hid kits I've ever used, the ones I bought back in 2007 are still kicking along just fine. I've been using them for my hid source since 2005. I didn't go with 55 watt because of the heat involved, it puts out tremendous amount of heat and and tend to kill the bulbs faster (all 55 watt kits) still use 35 watt designed bulbs so they are a little overdriven, that kills the bulb lifespan.
H4 is a dual filament bulb. It handles both high and low beams.
Regardless of 35 or 55w, it's better to make sure it's from a seller that has better made versions of the bi-xenon.
It needs a shield that completely blocks all light from hitting the bottom of the reflector housing when in low beam mode. That minimizes potential of blinding oncoming traffic.
Make sure you get a bi-xenon, and not the hi-lo type (that uses HID for low beam and halogen for high)... they are very bad for output. And don't get the single beam kits... you either lose high beam if you have a shield or have permanent high beam.
Thanks for the help guys!
RETROFIT! or else just use a different color halogen bulb. Waste of money to put HID drop-in kits in a Reflector housing... there are TONS of threads on this and why.
Check out Morimoto for the retrofit kits. Member [Dookoo] just did a retrofit on his car and a few others have used them as well.
~SB
~SB
anyways, what temp and watt you running on yours? looks nice
I'm using Osram CBIs and 50w ballasts. The color you see is actually 'color flicker' and isn't the color of the bulb but the tuning of the projector.
I use DDM Tuning 55w. It's work well for me for a long time. Cut off is apparent even though I have no retrofitting. They are a hit or miss type company, just like cars, you may just get a lemon. I only heard of one bad instance from a local Fit member that had an issue. Everyone else I know who bought from them have had no problems. They also have lifetime warranty on their HID kits.
As for the type to get, H4 Hi/Lo beam. 35w or 55w is your choice. The low beam only will lose your ability to have high beams and the shield is usually not efficient.
I had a 4500K DDM Kit for a week and took it off. I don't recommend the use of HID's in reflector housings, especially on the GE8 Fit since our housings are huge. It's unsafe and will blind others. I was that person who read the posts on this forum saying not to do it and did it anyway, thinking that it wouldn't be that bad. It was bad.
Do it right with a retrofit or buy a different set of bulbs. The Plug & Play HID kits are not worth it, especially taking into consideration of others safety on the road. Just my 2 cents.
What did your bulb look like? Mine has that chrome shield around it and it diffused the light perfectly like how a halogen setup did. No stray light to bug people. I have the same kit on my Honda vfr800
I ran a DDM kit for a couple weeks, didn't give me any issues but I wasn't happy with it. Output was worse than the halogens (as it will be with any HID bulb in a halogen housing) and since the back of the housing wasn't completely sealed it made my headlights fog up (I can also probably blame not having part of my fender liners because of that, but beside the point). Definitely either get better halogen bulbs or just retrofit.
