TPMS Lifespan?
TPMS Lifespan?
Hey all, I was wondering if anyone else had to change out a TPMS sensor not from breaking but just stopped working. The front left one on our fit just stopped working and had my friend pull the tire off to inspect it and it was fine but just didnt work anymore. Has this happened to anyone before?
Apparently the sensors have batteries in them, which eventually run down. What year and mileage is your car? I'm curious as to when I can expect to have to replace mine. I have an '09 with about 90k on it, and so far all sensors are working just fine.
Then it sounds to me as though you have a defective sensor. It might be worth a trip to the dealership to see if they'll replace it under warranty.
Thanks—that’s helpful.
A slight hijack: am I correct in thinking that there’s no need to remove the TPMS sensors when replacing tires on the rims? I ask because when I last had tires installed two different garages told me that they wanted to remove and then reinstall the sensors, and that in the course of doing so they had to replace the rubber washers that made the airtight seal—at a cost of $10 per wheel. Am I correct that this is simply a way for them to make money? Or is there some advantage to removing and then reinstalling the sensors?
^^^ Yeah you're correct.
I've had a tire replaced (within warranty), and just recently replaced all 4 tires last year, neither time did they have to mess with the sensors, just swapped out the tires. Afaik, if they do have to remove the sensor, the rubber washer(s) should be replaced, but I don't know why they'd do that... maybe as a preventative measure, but in the process of removing & re-installing the sensors they could possible break one (seen quite a few threads with that problem).
Damn, that's pretty good.
They might need replacing.
Bad one at 25,000 miles
Some people believe that the proper way to dismount a tire with TPMS is to remove the valve to let all the air out, then remove the outside nut holding the TPMS valve assembly and sensor on, then push the sensor into the tire so that there is no way that the tire removal tool can break the sensor. If so, then the rubber seals would need replacing.
_
sschoe2@gmail.com
09-07-2016 11:51 AM
