Has anyone used a Fram Sure Drain on a GE?
I have a 2010 Fit. I used the Fram Sure Drain (no longer manufactured, but still available on the internet) on my prior car and liked it.
According to what I've seen the oil drain plug is 14mm X 1.5mm, which would be the SD2 model Sure Drain. But when I pull up the 2010 Fit on some of the sites selling the Sure Drain it says not compatible.
Anybody tried one? I'm wondering whether it just doesn't show because they stopped making it by 2010, or whether it doesn't fit because of the shape of the oil pan.
The Fumoto shows the 14 X 1.5 which would be a Fram SD2 but there are other issues with fitting it- maybe it protrudes into the pan too far or sticks up in such a way that it might not be able to be screwed into the hole.
and unless you're tracking your car... how many times a year you going to do your oil change? like what, once or twice? that is just unbearable!! jk (just reality check).
IMO, get the Fumoto valve. Works great on my '09 GE, and gives exactly the advantages that you liked with the Fram. I had the Fram drain on my truck, liked it, but like the Fumoto valve on the Fit better. The valve also helps to keep inept service people from losing, forgetting, tightening too loose/too tight, or cross-threading your drain plug (for those who trust oil changes to other people). The best advantage of the Fumoto valve is, once it is installed, it never needs to be loosened or removed.
i just wear disposable gloves and rarely drop the plug in the drain pan...actually i cant remember if i ever did drop it.
You won't regret your purchase! I also have almost 50 years of car maintenance experience, and used the Fumoto drain valve (sold under a different name) on my '87 Ford Bronco, and could not find that type of oil drain valve again until I bought my GD Fit in 2006. Found mention of Fumoto on the forums and bought one, then bought another for the GD's replacement in 2008. The valves are worth twice the price due to high quality and all of the previously discussed advantages.
Which?
I used valves like these on the last car I purchased brand new, a 1985 turbo Chrysler GTS. The valve worked great, the car didn't work out at all. As I sold it I thought about keeping the quick change valve, but wasn't worth the effort. Don't know why I didn't bother in the dozen used cars I bought for family members since.
But when I go to the Fumotu page there are 4 different types F106 valves they show compatible w/1500cc Honda FIT:
f106s (short nipple), f106 (no nipple), f106n (standard nipple), f316l (right angle nipple)
The last two say not for low clearance engines, so I think I'll avoid them. I do like the idea of being able to push a plastic tube on it to direct the output...BUT WHAT TYPE HAVE YOU ACTUALLY PUT ON A FIT, SO YOU KNOW (not just think) IT WILL WORK?
(There are also extenders in case the valve will hit the engine case before seated.)
Site I went to: Fumoto Valve | Qwik Valve™ but you can find them on Amazon too...once you decide WHICH F-106 you want.
Paul H
Paul H
Triskelion do u got pic of urs installed
Paul H
Paul H
