Do you have winter/ice tires for your fit?
#41
You definently do not do an alignment that often IMO. However, you can't always "eyeball" your tires and determine if you need an alignment or rely on the car pulling one way or the other to tell either. Aligning the vehicle is referring to the vehicles suspension being in alignment which is most often involving the toe being set to within factory specs. Camber and caster do not normally need adjusted on our cars. Balancing is only referring to the tires and and rims. It is of course always required when exchanging tires from the rims, but not really if switching tires AND rims together. If the steering wheel or vehicle shakes at various speeds, normally freeway speeds, then it is usually a balance issue.
#42
Unfortunently you need a spin balancing machine. Considering they cost several thousands of dollars, you need to go to a repair shop. One thing that some places try to "upsell" on is road force balancing, but that is not normally needed unless you have a real issue. Normal balancing is fine.
#43
"I have never used snow tires, nor do I know anyone that does"
In Canada, where winter tires are an absolute necessity if not a requirement by law, many consumers buy steel rims and mount their winter tires on these rims permanently, thus making it easier to change the tires for winter. One only has to undo the lugs and change the wheel and voilà!
However, when I used to change my tires (putting winter tires on my existing rims), my mechanic always insisted on doing an alignment. Is this really necessary? What about if I had a set of winter tires mounted on steel rims? Would a wheel realignment be necessary when switching tires+wheels for winter or is this just overkill?
The only thing that would stop me is really deep snow, deep enough to bottom out, but winter/snow tires wouldn't make any difference there.
#44
I still don't think it necessary. We have snow, ice, slush, and all that nasty stuff here, and I get through it just fine on all season tires.
ive driven the 09 GE in deep snow (deep enough to scrap bottom) with WS60's. it didn't get stuck. meanwhile, a FWD suv got stuck so i had to pass him/her. clearly it was their all season tires that just couldn't 'get by' this time.
snow tires > all season tires (especially the ones that came with the car)
#45
safety is for people who can afford it. anyone can 'get by' with shitty tires. just dont have the confidence level or consistency as those that are prepared.
I've gone through snow where I was scraping bottom as well, and had no problem with the "shitty tires" as you call them. The deep snow I speak of is where it is higher than the bottom of the car, and the car settles down on it, or is completely blocked by it. Tires don't matter in that scenario.
It's all in the drivers ability to handle the vehicle, and road conditions. Around here, the roads are full of over confident and over cautions people. You either see them in accidents, or they are holding up traffic.
#46
I'm 100% confident in my driving abilities, and have no need to waste money on another set of tires. That's not because I can't afford them either.
#47
On my subaru (99 outback) I ran Nokian WRs. That was enough for the type of snow we get here, and with the AWD I had no problems getting out of the driveway. When it did snow I had no problems with the suabru, it was so well balanced and predictable that taking corners, sideways, at speed.
When that car died (spund a bearing...) I ended up with a 97 civic. I puts snows (altimax arctic, with studs, 185/65r14) on so I could claw my way out of the driveway (steep, up to the road) in the mornings. For the 2010 winter, I was glad I had them, lots of snow that year.
Last year, 2011, we had 14" of snow on october 29th (early for NJ!) And I got caught out in that storm with my dads 2007 outback with goodyear trippletrads. While the all seasons were "adiquit" that is all they were. I could get arround because I actually practice foul weather driving (drifting in snow covered parkinglots is fun too! I reccomend getting the feel for your car and tires) and the AWD was the only reason some of the hills here were possible.
I sold the civic when I bought my fit (2011, april) but kept the snows because they fit the fit. Though I have no reports on the fit in the snow because the only snow we got last year was that 14" storm in october. I actually put my summers on in the second week of febuary 2012!
#48
There are major benefits to snow tires but not everyone actually needs them. in areas with higher snow fall, I'd recommend them. Just my $.02
~SB
#49
A previous poster mentioned "AWD made the steep hills possible". That's an example of someone who truly understands winter driving. If you have a heavy rear load on a FWD vehicle and need to get up a steep hill covered with packed snow with all season tires, it's probably not gonna happen whether you are david coulthart or not whereas a granny driver in a Yaris will be able to overcome the hill. Why would you prefer a horrid driving experience to good traction on the basis that it's a "waste of money"?
I mean if you get snow and ice for 3 weeks a year then don't bother, but in Quebec, winter tires are a basic necessity and has been required by law for the past few years.
I would also caution the attitude of being over confident in icy conditions. Maybe you don't get black ice in ohio but if you tried taking a corner at 30 Mph and hit a patch of black ice with all seasons on, you'd probably end up doing a 360 and hitting the curb! Just because you don't see it doesn't mean it's not there and you'll only realize once its too late. No amount of corrective steering can save you if you hit a patch of ice with too much speed. I
#51
I had a set on a Toyota Sienna once, good tire. They felt very sure footed in our crap Ohio weather. Just too rich for my blood these days though lol.
#52
I have a 2010 Sport and I would have been happy to get the stock tire size or downsize one size, but Tire Rack didn't have wheels to fit those sizes. I ended up with 195/65 15 inch Continental ExtremeWinterContact's. They don't stick to ice quite as well as the Blizzak's I've had before, but they're much better in the wet and dry between storms. not too pricey, either. Certainly much better than the OEM's in snow.
Cheers!
Cheers!
#53
I bet that looks good. Integra alloys are like gold around here. Stupid prices or none to be found. Lucky!!!
#54
~SB
#55
Obviously no snow in the neck of the woods where I come from, so carry on
#56
Hope this helps!
#57
Interesting discussion. I grew up and lived a large slice of my life in Michigan, and have lived in Alaska. I now live in the mountains of SW Virginia. I've *never* used snow/winter tires and have yet to ever be stuck in the snow in any vehicle I've ever owned, including two Civics and an Accord (which I bought in Alaska). This sounds like a thread started by a shill for tire manufacturers!
#58
#59
Well, I've lived in the Appalachian Mountains of rural SW Virginia for 15 years, with two Civics the whole time, and have never had any problem with all weather tires on either of them. It's not unusual to see a 3000' altitude change within 5 miles around here, so I wouldn't hardly call it "flat" (flat is one thing we don't have). Never had a lick of trouble. I think honestly it's more about driving ability than what kind of rubber is on the rims.
#60
