Proper tire inflation?
One good thing about the old pencil tire gauges...you'll never pull it out to find the battery is dead and it's useless, like digital ones. :}
Paul H
I've used high quality round ones with a tail, like listed previously in this thread. I bought a round one with a bleed off valve for my fit, at my local auto parts store. Not super accurate, but not expensive either, and it's good enough for my purposes.
Paul H
just browsed the thread.... could have been answered already.
i have had the tpms pressure light come on from overinflation.
as mentioned, drop them down to 35psi...the light should go off after a little driving
FYI, there is a seperate light for a tpms error with the system, lights up with the letters TPMS, so the balloon looking tire only comes on when ther eis a pressure issue, not a broken sensor.
~SB
What a coincidence! My low pressure just turned on today. I blame the extreme drop in temperature the last 24 hours. All month it has been 100+. Then yesterday a storm rolls through, dropping our temp by about 40degs. I checked the tires and they were all at 25psi. I inflated to only about 32psi, because I figure the temps will go back up to 100+ in a day or two, which should heat up my tires again, which which gather should add pressure. Was it okay that i did this?
Tire gauges are fine but what happens when you need air? Forget driving to the gas station. I bought one of these for $60.
MotoMaster 12V Programmable Air Compressor | Canadian Tire
It allows me to check and inflate my tires anywhere I am since it plugs into your 12V outlet. I keep it under the cargo cover.
It's actually quite small
Whatever model you go with make sure you take it to your dealer and have them check the calibration. That way you will know for sure if it is accurate.
i use to have a fancy one similar to that and it died in 2yrs. i currently use this orange pos looking thing and it's been working great for 4yrs+ you can also set the dial to stop at a certain psi as well. i pump a few psi higher, then i use my digital gauge with release valve to set it perfect to where i want.
as for calibration, you can check the same tire with a few gauges. i have like 5 gauges of different shapes and they all are within 0.2 psi of each other. i tossed a pen gauge as it wasn't very accurate at all.
FYI, not related to OP's issue but wanted to pass along.
I've read that most TPMS systems also warn for a specific delta or difference in pressure between individual tires. Say the recommended pressure is 33psi then your TPMS light probably comes on at 25-27 psi for a low pressure warning. But if 3 tires were at 40 psi and one was at 33 psi it would also come on do to uneven pressure. Not sure if this applies to the Fit's system though. I looked but couldn't find anything about it.
_
_
_
_
I am no expert on the mechanics of a car, but my 2010 Fit had the low tire pressure light come on the day after I bought it! I did what I was taught to do. I looked at the PSI recommendation on the tires and filled them all up to that number with my tire inflator. Well, it says 51 PSI on the tires, but the other day I saw a sticker on the door that says to inflate to 33 PSI. So, my tires have been at 50 PSI for 2 weeks now. Is that bad? Anyone know what my tires should be inflated to? They also had Nitrogen in them, but obviously they now have regular air also.
The label 33 to 35 psi is good street pressures; you haven't damaged your tires running at 50 psi; racers and autocrossers do it all the time to get siffer tire shape and adhesion. The 51 psi is recommended maximum for comfort and performance.
air is 79% N2; 21% O2; the only advantage to N2 is the lesser expansion with heat, good in racing but not for street. N2 has a bigger molecule than O2 so the N2 weeps thru the tire carcass much slower than O2. Again its only use in long time storage.
Stick with air.
#33
regarding some of the 12v compressors available: An old BMW motorcycle trick to save space: Most of these have plastic outer shells for appearance and protection from high temperatures generated while working to inflate your tires. But you can split the case and discard it, leaving a small metal motor, connecting rod, and compressor unit. Takes up much less space: mine would fit in the tailpiece behind the rear of my BMW R1100RT seats. Just be aware parts move very quickly and get SUPER HOT, so when using it put it on the ground and don't try handling it. Will free up space at your spare...put it in an old lg sock or wrap in a towel so grease dosen't dirty your other stuff.
vwli
36
07-31-2014 04:01 PM
boots11234
10-27-2008 03:55 PM
