OEM Foglights on a Base Fit?
Has anyone had OEM Foglights installed on their base GE Fit? I'm curious as to how they are installed as I was washing my Fit the other day and noticed that there really didn't seem like a place for a clean Fog light install.
I would like to know before I have them installed.
if you're talking about the accessory fog light kit... you have to make cuts into the bumper where the housing goes. but the kit will come with "caps" that cover that area of the bumper and hide the cuts.
http://www.collegehillshonda.com/instructions/fit/2012/foglights.pdf (the url parser isn't working, so I turned off the parser)
Sounds like something I would MUCH rather entrust Honda to do. Lol!
I'm all for cutting a cheap air box for an intake or trying my hand at a Retrofit headlamp but dealing with the taking off the bumper, cutting it, wiring and such. I think I'd rather get it professionally done.
like I said, the cap will cover that area of the bumper. so, unless you slice a foot long gash... it'll be covered up.
I took off my bumper to swap my headlights and do the DIY lower grille mesh (while I was at it)... within a month of buying my Fit... and it was the first time I did any major mod like that. Actually, the second time I replaced headlights on a car, but the first car didn't need me to take off the bumper.
https://www.fitfreak.net/forums/2nd-generation-ge-08-present/57146-being-eaten-alive.html (post that thread on July 9th, but I only just picked up the Fit on June 21st).
But don't get me wrong... it's your choice what you want to do.
I did it and it wasn't too bad. You'll need two hole saw bits and a decent tool for removing the bumper, aside from fairly common tools. It is a hack job, but like Goobers stated, it gets covered up: The Honda techs will be doing the same thing.There are guide circles all along the back of the bumper, but unfortunately a few are at awkward angles so getting it dead on is next to impossible. I had to use a mini hack saw in places and unfortunately got a little over zealous with my cutting to get one of the assemblies lined up. This resulted in a one inch black mark that wasn't hidden. I'm okay with this given the much improved lighting and the fact I saved close to five hundred in labour to get it done at a local Canadian dealership. Besides, it gives me an excuse to do a Sport conversion down the road.
Glad you posted Connor as I was going to link to your thread.
StormSilverGD3
12-02-2021 10:39 PM
ImPuLsIvE.ca
24
07-15-2021 05:03 PM
JohnpaulX
01-12-2019 01:59 PM
