Best coilovers for Daily Driving?
Old 06-20-2012 | 01:15 AM
krunk13's Avatar
Originally Posted by lowkeymods
Well w/ any drop you have to consider offset/rubbing. However, I can only speak to my final decision on coils: Tein Street Basis. I took the information and experience from users on this forum and used it to research w/ local shops, manufacturers, and fitfreak vendors what would best help me accomplish my goals. The Koni's were a close second, but even the Koni vendor suggested that for my goals the Tein's were probably the best fit. Depending on how the Koni's are modified I feel that they might last a bit longer. However, the Tein's are rebuildable for $75 a corner by the factory. They suggest this every 35,000 miles. I think for my needs I just couldn't justify spending $600 more on Koni's. I can totally understand those w/ more advanced setups and realize that the Tein's are partially just $ going for the name. However, I felt like they were the most reasonable/safe bet for me.
Edit: In short, I don't think you can go WRONG w/ Tein but I think the argument from several users is that you can go much BETTER. I just don't really need better.
Thanks again guys! They're going on Friday.
How much did you pay for them?
  #82
Old 06-20-2012 | 01:59 AM
lowkeymods's Avatar
They range from mid $800+ depending on how long you want to wait/shipping.
  #83
Old 06-20-2012 | 04:17 AM
RangerRingor's Avatar
Best ones: AMR Engineering. Hand made in Seattle, WA. Made of high quality parts and it beats the warranty of any other coilovers. The owner pushes customer satisfactory. Plus, it's custom made to any set up you ask him to. I'm getting a set made for my Fit. Specifically for daily driving. Check them out man. I'm pretty sure you'll be definitely interested.
  #84
Old 06-20-2012 | 06:48 AM
spootnik's Avatar
Will do, thanks for the tip, I'll check them out :-)
  #85
Old 06-20-2012 | 10:03 AM
krunk13's Avatar
Dont the AMR's cost a arm, a leg, and your first born?
  #86
Old 06-20-2012 | 10:19 AM
solbrothers's Avatar
tein is shiny jdm trash
  #87
Old 06-20-2012 | 11:34 AM
spootnik's Avatar
Yeah amr cost too much, tomorrow I'll check a local tein importer. If it's up to $1500 I'll get tein otherwise buddy club n+. Good feed back in ozhonda :-)
  #88
Old 06-20-2012 | 06:30 PM
lowkeymods's Avatar
We'll find out. I do find it strange that my performance shop, the Koni rep, and multiple forums don't thinks so...but if that is the case I've been warned.
  #89
Old 06-21-2012 | 07:34 AM
AMR's will cost me my left and right testicle...
  #90
Old 06-21-2012 | 07:36 AM
krunk13's Avatar
Dont you need those?
  #91
Old 06-21-2012 | 10:42 AM
FitStir's Avatar
For daily, I was set on the Bilstein's especially with their quality & warranty, but now waiting on what's happening with the Koni's... otherwise I'll still get the Bilstein's.
Would love those J's Racing (especially the Crux) or HKS, but damn expensive though.
  #92
Old 07-03-2012 | 12:56 PM
Socialvegetable's Avatar
I can't really add anything yet, but I just ordered the Bilstein PSS kit yesterday. My stock dampers and Tanabe DF210 springs are beat (and as a result, so are my fender liners). Just drove 600 miles on them, and dear god was that miserable. I know the Bilsteins should last, and they are, to my knowledge rigorously tested for comfort and performance on our cars. If they're good enough for the B-spec, they're good enough for me.
Now, my concern, similarly to yours, is the range of height adjustments. I'm running 15" wheels and 205/50/15 S.drives.
I really just want to maintain my current height, which is a 1.5" drop front and 1.8" drop rear, as per Tanabe's data. I think the Bilsteins max out at 2" front and rear, so I don't think I'll have a problem, but seeing other people's photos has me a little worried.
  #93
Old 07-03-2012 | 03:49 PM
FitStir's Avatar
Originally Posted by Socialvegetable
I can't really add anything yet, but I just ordered the Bilstein PSS kit yesterday..... I know the Bilsteins should last, and they are, to my knowledge rigorously tested for comfort and performance on our cars.....
Yup. Post a review after you install them. I was set on the Bilsteins until Koni showed interest, but still leaning towards the Bilsteins.
Max drop on them is ~2" (1.96 to be exact), so you should have no problem maintaining your stance.
  #94
Old 07-03-2012 | 11:09 PM
Raindog's Avatar
I've been on the Bilsteins for about a week and a half now and am quite pleased with them. I'm getting a pop from the left front that's driving me mad but have identified the problem (perch) and am working to correct it with a buffer.
These with the addition of a rear sway and 17" enkei's make for an extremely agile combination that also rides well.
  #95
Old 07-03-2012 | 11:26 PM
wait, what is your fix for the pop? i have that on my gd
  #96
Old 07-03-2012 | 11:42 PM
Raindog's Avatar
Well, from what I can tell it seems that there is a slight lack of tension on the spring and movement is causing it to strike the center tube, again ever so slightly but enough to make noise. Wrapping the lower portion should in theory increase tension and provide enough buffer to eliminate the noise.
The older focus springs had these from the factory and I've thrown away a million of them but don't see them so much anymore so I'll have to search the shop to see what I can come up with.
  #97
Old 07-03-2012 | 11:50 PM
aaaaaaaaaaaaaaah that rubber wrap? I know what you're talking about. I think my problem is a blown shock :s
Badwrench
14
04-21-2014 06:46 PM
mo-FUK
08-12-2012 10:59 PM
DrKelso
13
04-08-2009 06:02 PM
DeNNis.
04-05-2008 06:51 PM
ofay
02-10-2008 11:57 PM
