Desperate need of help installing swift springs!
I can't get my axle back in with the strut. We tried everything but it's not working and the holes aren't matching. I am starting to freak out it's 2:00am and I don't know what to do! Please Help!
I used rubber straps from Home depot and it worked great. I agree you definately need them to keep the axle out. I didnt have them when I was putting my swifts in,stopped and took a cab to home depot to make sure I would be screwed by the axles...
I heard if it falls out it may take time to spin in while trying to get it back in.
^ This ^. Exactly what I did. Keep a jack under that bitch and it won't be going no where. If it does come out then do the twisty push and it should pop back in.
I've used this method many times, and never had an axle pop out on me.
Glad you got it back together, i've had many 2 a.m. WTF moments myself and understand your stress
Yeah, sorry for this panicking post but we started at 8pm, and it got into 2:00AM! Finally finished but there is a clicking noise when I hit a hole in the road or something. I believe I didn't have air tools to tighten the sway bar link tight, is that correct? Plan to tighten as soon as possible so nothing bad happens.
I got it for $258 or something from evasive including shipping, nice deal.
You should check and tighten everything after you drive for a little bit anyway. It's just good practice.
Mitsukeru
02-21-2010 07:08 PM
2008, 2012, fir, fit, fitfreak, freaks, gimmy, honda, install, installation, installing, instructions, springa, springs, swift
