How to put a bluetooth device on my honda fit sport 2009 a/t without nav?
I got this, works pretty good: Amazon.com: Jabra DRIVE Bluetooth In-Car Speakerphone - Retail Packaging - Black: Cell Phones & Accessories
The Canadian Fit has bluetooth standard for 2012. Their non-nav radio looks the same as our 2012 radio. Wonder if that would be a possibility?
I have a parrot MiniKit Slim and also the Garmin solution which both work well. I've moved over to Belkin's Aux input Car adapter which has a 12v Accessory plug (with usb charger), a single button (with microphone built in) for placing/receiving/ending calls (and for starting/pausing music) and it plugs into the Aux input on the FIT. I got this because I now use my phone for music, navigation, etc... and I don't want to hook up stuff when I hop in the car (as my commute is less than 10 minutes). I used to plug the car into the cradle and it went to the aux input and that was fine for a 35 minute drive. With my 8min commute, I find that i forget the phone in the car if I use the cradle so the belkin bluetooth works great. Press the button twice and I'm listening to music. (I still need to figure out where to mount it though. Right now it's under the parking brake)
If you don't have a droid or iphone with GPS, go the garmin route
The Parrot minikit slim is nice and feature rich for a BT speakerphone but the battery needs to be recharged every few days if regularly used. If not, every few weeks is fine (uses mini USB, not Micro USB) - I use this with my Blackberry and the Belkin with My Droid X2
Lastly, a Decent head unit replacment isn't a bad Idea if the cost isn't bad for you.
~SB
~SB
While the USB connection can be added to an older radio via a plug in module (and that's a couple hundred dollars), I think bluetooth would require changing the head, plus the steering wheel switches, microphone etc would be difficult to manage. The cost of this would be prohibitive compared to an aftermarket head.
This worked great for me: Pioneer FH-P8000BT CD receiver at Crutchfield.com
Feels like it was built by the OEM
How visible is the display in direct sunlight? That's sometimes a problem. I like the Fit's stock back-lit LCD. I also like "radio data system" for telling me what I'm listening to (none of the aftermarket radios seem to have this).
That looks like a good option. I like that the USB connection is on the back so you can route it wherever you want instead of having a fob sticking out of the dash. And the bluetooth will pair with a media device for playing music (is that common?)
If you go through w/ the install, it I posted about it: https://www.fitfreak.net/forums/2nd-...rned-pics.html
exl500
07-21-2015 01:35 PM
Mobocracy
02-19-2013 12:34 PM
