PLEASE HELP, my fit died at 15,xxx miles
Old 02-18-2012, 09:09 AM
Euromedic's Avatar
And you still have a job (thanks to the Fit).
Old 02-18-2012, 11:26 AM
Steve244's Avatar
I'm grasping for a moral to this story. Help me.
Old 02-18-2012, 12:37 PM
fawbusha's Avatar
Well if being in the military has taught me anything it's don't be late or your going to get f##ked. So the moral of this story is, be responsible and strive to be 15 minutes early.
Old 02-18-2012, 03:03 PM
einstein77's Avatar
You don't seem to understand. If the Fit were a better car it would have made it there 15 minutes before he did and gotten the promotion for him.
Old 02-18-2012, 06:29 PM
neteng101's Avatar
Wrong. If anything, the OP was striving too hard to get to work on time, and sometimes all the best laid plans even can go to hell. Getting to work safely, without damage to your car (or others) is far preferable, to absolutely always being early/on time regardless of cost/consequences.
Learned that a few years back, got into a bad accident because the client I was working at was being an absolute ass. Never will do it again - you can fire me first. No job, boss, or whatever, is worth putting your own life (and others) in danger.
Old 02-22-2012, 11:17 PM
rprpclark's Avatar
I like to blame others for my actions also.
Old 02-24-2012, 11:41 PM
jondotcom's Avatar
1) Don't rice your ride
2) Don't break your ride if you rice it
Remember, this involved the beloved combo of a modded intake, painted V/C, and a "hacked exhaust." It's classic, really.
Old 02-24-2012, 11:59 PM
raytseng's Avatar
I think the moral is:
If you're getting fired for being late and you had an excuse such as car brokedown,
Maybe it's FML OR maybe there's some other things you've done which led to this breaking point where you have no chances left.
http://en.wikipedia.org/wiki/Cognitive_dissonance
Either way, maybe it's time to contemplate if there were some poor decisions made or bridges burnt which put you in such a vulnerable position that a single random event of a car breakdown is all it takes to completely ruin you.
Old 02-26-2012, 03:08 PM
kgb4187's Avatar
Originally Posted by BlackPearlFIT
i know hondas like to throw that light if the engine was missing, i hope it wasnt missing at 15,xxx miles... wtf could this be?
Did you look under the hood to check to see if it was there? I don't think you'd be able to drive if the engine was missing...
Old 02-26-2012, 03:38 PM
Shora's Avatar
Very mean comment....
However, super happy that I didn't have my coffee yet as it would have been all over my computer.
Old 02-27-2012, 10:03 PM
Dougr320's Avatar
why would you do half ass ricer mods to a brand new not to mention slow car like the fit. Better time managment and get a sports car if you wanna play around with it
  #32
Old 03-07-2012, 10:57 PM
FitsMePerfect's Avatar
I took my Fit to the redline once since I bought it and never again. Wake up 15 minutes earlier and don't redline it would be my advice to you.
  #33
Old 03-08-2012, 12:10 AM
Texas Coyote's Avatar
The engine can't be over revved unless you wind out pretty tight in 4th gear and when shifting to 5th you accidentally hit 3rd... The rev limiter does you no good at all when that happens... My rev limiter has been raised 400 RPM and I rev right up as close as I can get to it before shifting.. Sometimes I hit the limiter by accident in 1st or 2nd but other than making me feel like a dumb ass it really isn't doing any damage when it happens.
  #34
Old 03-08-2012, 09:52 AM
einstein77's Avatar
Done the same thing numerous times... no problems... just drops out for a few seconds.
  #35
Old 03-11-2012, 11:04 PM
kmpoling's Avatar
Fit top speed
Originally Posted by schuey1010
Not sure where you live, or where you work, but if you are not a problem employee, and don't have a stack of write ups in your file, they will have a pretty difficult time firing you over being late a first time.
I didn't even know that a Fit could even reach 80mph.
A stock Honda fit can go as fast as 115 mph.
  #36
Old 04-01-2012, 09:14 AM
kdburtch's Avatar
I think the moral is dont destroy your car to save less than a minute.
  #37
Old 04-01-2012, 02:16 PM
Cat's Avatar
Cat
Cat is offline
I set my clock 30 minutes ahead for the time I want to get up. I've never been late for work because I always make sure I am there 30 minutes before hand. I am old school and believe you go in 30 minutes early and you don't leave when the clock hits 4:30 PM unless you are done for the day.
Glad to hear your Fit is OK
  #38
Old 04-02-2012, 04:50 AM
kgb4187's Avatar
You joined just to post this.
  #39
Old 04-02-2012, 06:41 AM
121 had her there 3 times, but careful of the harsh limiter when you hit it. Scared me the first time how much it slowed down by engine braking alone.
  #40
Old 04-02-2012, 02:01 PM
My Fit has been supercharged and has a few other performance modifications so there is much more stress of the engine and drive train than one that is stock... I have to use higher viscosity oil in it or it consumes more oil lost by way of blow by when on boost but other than that I have had no problems other than an exhaust leak at the exhausts header that I'm removing today to find the cause... It is almost impossible to not hit the rev limiter in 1st or 2nd gears at full throttle. With my ECU reflashed and the limiter set to rev 400 RPM higher there has been no problems... I don't think you can break one of these engines as long as the air/fuel ratio isn't wrong, the cooling system is working and there is enough oil in it.
Quick Reply: PLEASE HELP, my fit died at 15,xxx miles
