Honda deception
#41
I think we should have a sort of sub-forum where we can banish threads like this. That way, we can keep all the stupid threads in one place whenever we feel like laughing at them, and focus on just having good, helpful discussions in the real forums.
#42
Something tells me he probably won't be around; it seems like he's a pretty infrequent poster, posting only 2x in 2009 and then, mysteriously, popping up with this gem. Either way, hopefully the math in here, simple as it is, helped him and maybe someone else that didn't know.
#43
Yeah, I think we chased him back to the bridge he was living under. Oh well, until the next trolling...
Here's what I think what he would have posted:
Fake DommoPA: But guys, don't you see that there is no way peak HP can't be derived from peak torque? It just doesn't make any sense...I've got a Bachelor's degree (B.S.) in mechanical engineering from the Magical Numbers of Pennsylvania Online School of Science and Wizardry that tells me Honda is wrong, wrong, WRONG! Ignore their entire history and all the brilliant engineers they have working for them, I just made them all look like drooling retards with my expertise. Just look at this equation:
(106*4800) / 5252)+(VTEC-400 lbs.)*(pedal pressure/Average American foot size-Japanese foot size)^10 hot dogs = 96.877
BRB, contacting my lawyer right this minute.
#46
The formula DommoPA is using is:
HP = (2pi)(RPM)(Torque)/33000
(33000 is James Watt's observation of how much work a horse could do in 1 minute - pull 330 pounds 100 feet in one minute)
so,
HP = (6.28)(4800)(106)/33000 = 96.8
However, this just predicts the horsepower AT THAT RPM.
If you look at a torque and horsepower curve for this engine
such as at:
The Temple of VTEC - Honda and Acura Enthusiasts Online Forums > Hey look, it's a power/torque curve for the CR-Z! > > Re: CR-Z vs 1.5L Fit Torque Curve
You will see that the horsepower curve at 4800 RPM is in good
agreement with the formula. You will also see that since the rpms
can still increase faster than the torque rolls off, the max developed
horsepower occurs at ~6600 rpms, which is in good agreement with Honda's
published specs.
No deception that I can see.
so,
such as at:
published specs.
#47
As for your MPG in the city, first you have an automatic mistake number one, second it sounds like you don't know how to drive the car properly mistake number two. If you want the baller MPG people get without hyper techniques for driving, then first go get a manual transmission fit, get rid of the factory crap tires, and learn to drive a stick PROPERLY. When I say that I am assuming you don't know how to drive a stick properly, which is an assumption, however 90% of those out there don't know how to drive their sticks properly anyway so it's probably a safe assumption.
Or you could just trade your fit in on a Prius and stop complaining about problems with the fit that don't exist. Oh and even with the massive weight of my stereo system in my fit I still manage 33-35MPG city in Florida, so yeah it's not the car, it's you.
#48
so,
such as at:
published specs.
so,
such as at:
published specs.
#51
We got another good one in progress here:
https://www.fitfreak.net/forums/fit-...-fit-jazz.html
This one I'm not just being a snarky dick about though. Well.. sort of.
#52
2010 Sport / AT / Navi / 18,000 miles / otherwise, stock:
Honda is "playing fast and loose" with the specs. on the Fits to jack off the buyers.
They say HP is 117 at 6600! ...
My engineering specifications calculated from their published figures equates to only 96.87 HP at 6600 rpm..
Plus, I don't get anywhere near the 27 mpg city with branded gas. Highway only mpg is very good.
Questions:
Questions:
- Does anyone out there know a tuner / mechanic that knows how to fix this?
- Has anyone had MPG improvment using iridium spark plugs with a stock heat range?
- Is there any talk of a class action suit regarding Honda Fits ONLY based on lower than expected city gas mileage?
#53
how are you getting those numbers? did you dyno your car? do you realize automatic transmissions dont get nearly the fuel economy the manual transmissions get? did you realize automatic transmissions are terribly inefficient? it's robbing power and killing your fuel economy.
#54
Here are some dyno numbers for the GE8 of AT vs MT
The AT puts down about 80hp / 75lbs torque to the ground (and does 0-60 in some odd 10 seconds)
The MT puts down about 96hp / 92lbs torque to the ground (and does 0-60 in some odd 8.3ish seconds)
Going by if its true that the L15A7 pulls around 117hp on an engine dyno, thats about 18% loss for the MT, and 32%!! loss for the AT
Torque converters rob power, plain and simple.
#55
im sueing... everyone... for breathing my air... and.. uh.. honda.. for being reliable... and.. getting better than epa milage. i mean. they are liars. wtfs.
i hate humanity. people are so dumb its not even funny.
#56
As it's already been discussed in this thread, an auto IS more inefficient than a manual when talking about power to the ground. The only reason it gets better highway mileage is it spins at a lower rpm in top gear.
#57
All I care about is I can control the car to its full potential and hyper drive it to around 45mpg city
#58
True...half the world is below average in intellegence.
#59
45 city? Pretty good. Best I can do in town is about 40. Much better on the highway. And much better than I got with my M/T '09 fit.
