GE headlights question
can you experts out there tell me this set of lights work or not?
look like the seller is from US...
so I assume his product should work in NA FIT...
thanks
09 10 HONDA FIT 2X HALO LED PROJECTOR HEADLIGHTS BLACK | eBay
thanks
I have a set that came out just before that design did. The fitment problems are mostly the top two mounts that don't line up. The top one near the front is only off by a few mm (holds the top of the bumper and grille cover). But the top one near the back is off by much, much more. In the end, my bumper is drooping slightly without the top part being attached.
The design the OP put supposedly fits better, but I haven't seen any confirmation of it.
If you like them, get them, personally I have to agree with BlueBoogers.
Not nearly as bad as I was expecting but still not quite HID projector quality. I doubt it would be too hard to tear them down and retrofit it or even quad it if you really wanted to get some damn good lighting output. Even though I'm not a huge fan of the look. The Halo's and the led strip would have to go.
i have a set, haven't put them on yet since car is in storage.
I have to agree that they are a bit riced out with both the led and the halos, but the question is can it look good? In my opinion, it looks great on K's black fit. Thing is I really cannot imagine how they'd look on my white fit, which the alanchan also has.
I see a couple of local fans got these lights
do you mind tell me where you buy them from? was it through ebay?
or a local supplier
I like to get it install in my car
if someone knows how to install (I mean the electrical side)
I can do the bumper removal and all the work but not wiring
well, I have HID installed now
please contact me
alan_c888@shaw.ca
thanks
hey guys, thanks for your great comments
or a local supplier
please contact me
alan_c888@shaw.ca
thanks
or a local supplier
please contact me
alan_c888@shaw.ca
thanks
thanks but I paid someone to install HID for me already
is HID consider OEM?
my understanding is OEM is stock wiring
can I use my HID setup in these lights?
k20a298ek, Care to chime in on this one?
hey blackvitzrs
I think the lights should look good in our white color FIT...
the black housing will make it stands out even more in the white body.
by reading your post, you haven't install the lights yet.
do you want to do it together if I buy the set?
I am not sure how to handle the wiring because I had HID installed.
503ge8
09-14-2022 01:33 PM
connor55
02-24-2013 02:53 PM
