Maybe I Should Get the Accord
#42
The car is supposed to dissipate the force to save the driver, so you need to look inside the car and evaluate what happened to the driver, not the car.
#43
Why do you want a different result? I think you're making the assumption that the end result is bad. The ratings for this car is good not bad.
Honda Accord versus Fit: The structure of the Accord held up well in the crash test into the Fit, and all except one measure of injury likelihood recorded on the driver dummy's head, neck, chest, and both legs were good. In contrast, a number of injury measures on the dummy in the Fit were less than good. Forces on the left lower leg and right upper leg were in the marginal range, while the measure on the right tibia was poor. These indicate a high risk of leg injury in a real-world crash of similar severity. In addition, the dummy's head struck the steering wheel through the airbag. Intrusion into the Fit's occupant compartment was extensive. Overall, this minicar's rating is poor in the front-to-front crash, despite its good crashworthiness rating based on the Institute's frontal offset test into a deformable barrier. The Accord earns good ratings for performance in both tests.
#44
FWIW IIHS news release
Intrusion into the cabin is bad, and there's a good chance of getting at least one broken leg. This is the IIHS's analysis of their test (which is what the video is from. Its more than just looking at how damaged the outside is.
#45
#46
I would rather replace my bumper than bend the unibody in a low speed accident, I wish we didn't have them at all.
#47
FitNFoxxy
03-06-2013 10:29 AM
dredayfit
03-22-2010 08:58 PM
