Worst MPG ever
#41
People forget that more than the engine needs to warm up like the drive train lubricants.. In the real old days of manual chokes (automatic chokes were engine killers) you wanted to use it as little as possible by opening it as gradually as you started moving or opening all the way while sitting still, letting the engine warm with out diluting the oil then driving off as soon as the throttle could be opened without stalling the engine....It is a good idea to drive off as soon as the engine starts but without putting more of a load on the engine, drive train and even tires in very cold climates..... I can understand why a person living in an urban setting would choose to at least let their engine warm before taking off...It is almost impossible to drive off without having to put a load on use high revs on your car before everything has reached operating temperature when you have to be merging and driving with fast moving traffic.
#42
The new cars just need to step down once from start up fast idle, it usually takes a few minutes at most depending on how cold. In my Civic it take me 20 minutes for the engine to get to fully warmed up. 3 miles to the tollway and about 4 miles at 65 mph. Also I notice when getting off the highway and idling for the lights it cools off a lot thats due to the aluminum motor.
Oil is a lot thinner so it does not need to warmed up as in the past. I plug my truck in so the oil is warm and its 15w40. Sometimes the plug blows a fuse but it usually starts but cranks slowly with 3 batteries.
#45
I’m inclined to agree with those who say to start and drive, gently, without letting the car idle to warm up. But here’s a question. I’ve noticed that most automatic transmissions delay the shift points when the engine is cold. I assume that this is so that the power is generated more from RPMs than from torque, which will reduce loads on the bearing surfaces, a good thing when your engine is cold and the oil is not yet flowing freely. For those of us with MTs, should we drive gently and delay shifting when warming up the engine?
#46
With my last two fill ups at 27 mpg (actual) , I am also unimpressed. Especially compared to reading some of the claims here of 30+ mph around town. I have been driving more conservatively than I'm used to, and am obsessed with the mpg bar, coasting down side streets and easing off the gas on the highway when I have some momentum or on a decline. I checked my tire pressure, they are at the recommended pressure (33 or 34?), with the next fill up I plan to increase the pressure to 36 and see if that makes any difference. I fill up with Shell regular from the same gas station.
As far as warming up, I idle for a minute or so and drive very gently till the cold water temp light goes off, then I drive a normally.
Although percentage wise, it is a good increase from my SE-R which got a consistent 20 mpg without babying it, the difference in power and acceleration is significant. I really noticed it on a short merge when someone didn't want to let me in. The pickup on the Fit really sucked in this situation.
#47
To answer your question yes delaying shifts but keeping the rpms below 3000 rpm is what you want to do for about 10 minutes but that is dependent on how cold. The rule of thumb is until the engine is 2/3 warmed up but its not exact.
#48
ok, i had a 2009 fit s auto and averaged 35-39mpg the whole two yrs i owned it! traded it in on a 2011 and have had it since april 2011. ive got roughly 12k on the car now, from day one ive never achieved over 23-25 mpg. yes its accurate, its a 10 gallon tank, i get 230-240miles per full tank! im in houston, so its a mix of city/country driving. i dont mash on the gas, in fact i try babying it to improve mileage. ive tried various tire pressure levels to find no change as well. been to honda on the matter several times, all i get is excuses. its not broke in yet, its the weather, its the roads, its my driving style, blah blah blah. all bs! i feel like turning it in with the keys and telling them its not meeting its factory promises, im not paying for it! but yeah that just destroys my credit and makes them more money in the longrun. i dont understand this, any insight as to what may be wrong. the only difference i see between this 11 and my 09 is this 11 has the traction control button thingy wich seems to make absolutely noooooo difference when on! whats goin on with my fit????
I would be very upset if I were you, specially if you bought the car brand new. I would ask if they can exchange the car for another, or maybe a trade in where they take a couple thousand off for the troubles? Worse case scenario these cars are pretty high demand and even tho it would be a pain in the ass and you would have to pay tax on another car you could always sell it and buy another fit or a different car.
#49
Today's fuel injected computer controlled cars really don't benefit/need a cold start warm-up. Get in, start it up and drive on. Common sense tells you not to race off. The most warm-up I give my FIT is the time it takes to scrape window ice/snow off, then I'm off. Does this effect MPG??? Probably, but letting a car sit to 'warm-up' is a waste of fuel.
I've settled on 36PSI cold all around, with the OEM dun's and my new DWS's. It returns a better MPG and improves handling, though there's a lot of opinions on the forum. For a while this summer I was setting them at 36hot after a 60min run on the turnpike. That equated to 34cold for me, so you might very well be right on.
#50
The bad thing about driving at low RPM to conserve fuel is that it doesn't work... A scan gauge or similar device that you can monitor throttle position and ignition timing will show you that a light foot and high RPM will allow your ignition timing to advance more and the throttle to need to be opened at a lower percentage... It works well with manual transmission cars and might with an automatic also.
#51
Don't know why nobody else chimed in here. I'm not a mechanic but I would say there is definitely something wrong with the new car. 2 questions: is the new car a automatic like the old one?, and why did you get rid of the old one? Sounds like something on the car is defective causing bad mpg, bad spark plug or oxygen sensor, leaking fuel injector or something keeping the engine from getting the correct amount of air or fuel??
#52
haha, the mileage thing is just one of my issues!
1.the anti lock brakes lock up alot!!
2.the drivers door sometimes wont shut all the way! (idk, dont ask!! its weird)
3.the hood fits illfully! (one side sits higher than other at top corners!)
4.the rear hatch isnt aligned properly or something! (larger gap on one side than other when closed!)
5.the engine stutters often!
6.the tranny seems to radically downshift more often than it needs too!
7.theres two mysterious bubbles just appeared in the paint in my rear bumper lower left side tha looks like paint bubbles when glanced at, yet upon closer inspection something seems to be poking from behind the bumper cusing two bumps wich has made paint crack! (weird!)
8.window motors stutter when going down, only front ones, intermittently occurring, mostly passenger side!!??? lol
9.tons of creaks, rattles, vibrations from interior!
10.and one of most aggravating (though kinda small) is one tire i have to air up every three days religiously from day one of owning the car! been inspected by honda several times for them to just say they dont know, theres no leaks or punctures! they act like im making it up! lol but every three days it goes down to about 22-25lbs every time! now tires are outta warranty so they really act like they dont wanna resolve it!
theres more im sure, thats all just off top my head! im tellin ya, i cant believe this cars a honda! ive owned 23 hondas over the years, from garage built beaters, to track terrors, to super clean builds, NEVER had this many probs! freaking sucks man! so unhappy.
#54
funny enough i found this posting (wich is pretty old, but nonetheless!!) sounding by his description the same as one of my above mentioned issues regarding the paint bubbly thingies that look like something from inside poking it out!! anyways here it is!
Maybe this is a thread that needs to go to honda, because when i got my car back from the dealer i took the stupid front license plate holder off and there were two pin sized dots on my bumper. It didn't look like something on the road damaged it, because the dots felt like they were coming from the inside. Having the guy buff them out while its at the body shop. Could possibly be a manufacturing flaw?
anyone else seen or ran into a similar issue?
#55
and back to the mileage thing, my shits getting worse or something. claims i got 23mpg on computer thingy when i filled up earlier today, yet out of my last full tank it says i only got 188.7 miles??? what the mother f&$k man!!! im gonna lose it!
#56
It could be that you are in the habit of not filling your tank all the way up to the top of the filler tube every time you fill,,, Don't tell me it will mess up your car because I have heard that shit before..The only time I get bad mileage is when I don't top it of,, If you stop on the 1st or 2nd click you have no idea how close to full you have gotten and may have room for another 3 or more gallons in the long filler tube.I have been doing it for decades on numerous cars and motor cycles... It you haven't been doing that way you have found your problem,,, @ of my recent tanks was because I was short on cash and didn't get it filled to the top.. I got 25MPG that time and was pissed off big time. When I remembered what I had done I felt better but was kicking myself anyway... If you do it any other way you will never know when your figures are right
#57
jango- I just bought a 2012 base, same color as you and Im nervous now this color could be bad luck or something. I cant say Im having any of your problems except it downshifts alot but I hear they all do on inclines or when stepping on the gas a little.
#58
I've got a 2012 fit, mt. The first ~1500 miles were ~30mpg, and after a 10hr road trip, I'm now constantly getting 34, driving her pretty hard. It's also winter, so that's 34 with crappy winter gas, doing 75-80 on the highway.
#60
Something ain't right
If a dealer can't/wont tell you simply why a tire is dropping air??? Somethings up.
K_C_
