12mm Spacer Dilema
Old 12-30-2011 | 09:27 PM
gnuman05's Avatar
12mm Spacer Dilema
I'm thinkin' 'bout getting some 12mm Ichiba V1 spacers for my rear wheels to sit flush, however, I am running on 16x6 OEM wheels. Will the extended studs, which are 50mm, be to long and pose a problem for the stock, close-ended lug nuts? I believe that the OEM studs are 36mm in length, so the addition of 12mm spacers with the 50mm studs should leave a 2mm difference.
I also heard that the rear studs are on the bearing assembly and that you should not try to beat them out with a hammer because of damage to the bearings or sensor. Is this true?
Old 12-31-2011 | 06:11 AM
Pang3t's Avatar
20mm spacer/adapter will sit flush on OEM wheels. imo
also i wouldnt go extend stud id just get a spacer/adapter
Old 12-31-2011 | 09:53 PM
mahout's Avatar
First, you need to be sure that the extra 14 mm of lug bolt length really extends that much more from the hub face. If it does then a 12 mm spacer should use as many threads as original. But you will shorten bearing life.
Second, true and you should use studpusher to remove rather than a hammering.
Old 01-01-2012 | 12:33 PM
Chad T's Avatar
If you just go up 3mm to 15mm you can save a lot of hassle by using adaptors. These are adaptors.
Old 01-01-2012 | 09:35 PM
gnuman05's Avatar
Thanks for all of the advise everyone. Yeah, I think I'll spend a bit more and get 15mm adaptors.
BlueBoogers
05-13-2012 09:57 PM
vbpsport
11-08-2011 12:32 PM
xFERNx
10-19-2010 07:20 PM
Mr08FiT
09-25-2009 08:25 PM
Will I Am fit.
04-02-2009 02:12 AM
