Scott's Canadian TW GE8 LX V2.0
#44
Wow, nice looking car. It is cool to see just how good a base (or LX in this case) Fit can look. We don't get body color mirrors ont the base here either, though I like the black with my white fit. I am currently on the prowel for a sport spoiler that I will paint black and put on.
I also wish I had access to a lift. Lucky.
#45
Definitely post up moar pics AcousticAudio.. nice build.
#46
i second that. Was going tofabricate one out of alu plate, but this will be less expensive and easier Did you notice any difference in regards to highway speed and turbulence from wind/trucks?
#47
I've been debating trying to determine just how much colder (if at all) the air my home-made short ram [with heat shield] takes in is then the stock air box. I could do this by connecting the Honda diagnostic system to my car and watch the live data, particularly the IAT sensor readings, as I do say a 30km drive on highway and in city and record my findings. Then repeat on a stock fit I could just grab off the lot or one that is in the shop for work. Then compare the figures.
#53
Well I have only driven on them for a month in the cold and with my winter heliums w/ 195/55 x-ice... but I can say that it does already feel alot more responsive to my inputs, obviously much firmer, and on its softest setting its very comparable to the factory ride. Overall the car feels like it has greater agility as compared to with the Eibach springs. Super glad to have the Progress 19mm RSB though, the car is perfectly neutral between understeer and oversteer
#54
Nice work. I am interested in the under engine panel thinking it might result in 1-2 more MPG:
1. Did you have to drill holes or cut anything out on your car prior to the install?
2. How do you drain oil. Is there a OEM hole? or did you have to cut on in the panel?
Thanks,
Dan
Thanks,
Dan
#55
Thanks,
Dan
Thanks,
Dan
And as for doing oil changes, he just cuts the ties and put in new ones.
#59
Hey great looking car, and thanks for sharing all the photos!
Quick question, how did you manage -3.5 camber?
Keep us updated on what you need to do with the fenders to fit those wheels without rubbing. My setup is nowhere near as aggressive as yours, but this is a great reference for me!
thanks again
thanks again
