Check Your Spark Plugs!!
Old 01-16-2022, 11:45 AM
Mister Coffee's Avatar
@steve37 That's an interesting bulletin, Steve. I once went to a fastener manufacturer in SoCal — can't remember the name, but the initials were something like APD and it was somewhere like Oxnard — to upgrade some footpeg bolts on my Yamaha R1. The guy behind the counter said to always use a lubricant of some kind on bolts, but he noted that a lubricated bolt will tighten with less torque. With regard to spark plugs, the NGK bulletin sounds good, but I will add this: When I changed out my OEM spark plugs on my '13 Fit, one was in so tight that I had to use a pry bar. I got lucky, and it came out, but things could have gotten ugly.
Obviously, with spark plugs, you want them tight enough to stay put but not seize or break. I tend to cover-torque things in general, but I have never broken a spark plug. I don't know what causes seizing or if using anti-seize automatically means that the plugs are less likely to stay put.
  #62
Old 01-16-2022, 03:47 PM
steve37's Avatar
Makes one wonder if maybe some of the spark plug problems are because of anti-seize.
  #63
Old 01-17-2022, 11:12 AM
Okay, but why now and why this engine? We've been using anti-seize on spark plugs for years.
  #64
Old 01-17-2022, 02:23 PM
steve37's Avatar
I don't know...but I've heard many recommend anti-seize when installing plugs. Maybe the plug coatings have changed in the last few years?
I can understand (from the bulletin) how this could easily happen.
  #65
Old 01-17-2022, 03:57 PM
GAFIT's Avatar
Since it's happening on the factory original plugs I'd say this has nothing to do with anti-seize and even less to do with over torqueing. I'd say it's the opposite...under torqued plugs. My understanding is that Honda even revised the torque suggestion from 13 to 18 ft lbs at some point.
90k Ish is the miles my buddies, bought new, Fit made it to on the original plus before it ejected #3.
  #66
Old 01-25-2022, 08:56 PM
HFIT2012's Avatar
Update
Spark plug blow out is a known issue for 2009 - 2013 Honda Hit. See 2017 Manufacturer Communication posted to NHTSA website (https://static.nhtsa.gov/odi/tsbs/20...06924-9340.pdf).
Last edited by HFIT2012; 01-25-2022 at 08:59 PM. Reason: 2017 MC state it's for 2009 - 2013 Honda Fits.
MEATBABY
20
04-28-2017 12:50 PM
Hondarian
01-15-2017 09:57 PM
Buildingteapots
12-11-2016 08:38 PM
Harriswt
03-19-2013 01:56 PM
runbikerun
10-06-2011 02:53 PM
Quick Reply: Check Your Spark Plugs!!
