Break in oil
You'll get different answers from everyone you ask about this. My standard routine, and followed with the Fit, is change at 500 with dino oil, change at 2,000 with dino oil, change at 5,000 with full synthetic and then change every 5,000 miles thereafter. I have never had a car that burnt oil and have had several with over 200,000 miles.
If I were in your shoes now, I would change immediately with synthetic. It should be plenty broken in.
Honda says keep the factory fill oil in for a complete cycle on the MM. It's in the owners manual I believe.
My FIT went 9Kmiles before it's first oil change. Dealer service explained Honda engineers are particular on engine brake-in and the full cycle is the recommendation. You can then switch to synthetic, however, my service said wait till the second oil change.
It took me a while to adjust my brain to an 7-9K mile oil change, but it's the 21st Century and a great engine.
Like I said, you will get tons of different answers. I have built several motors and owned tons of new cars and never had an oil consumption issue using my methods. Others have followed the factory recommendations (which are monitored by the EPA) and not had such good success.
I changed mine at 4k, ran conventional oil for another 5k and went ahead and changed to synthetic following that.
The only reason I ran conventional following the break in oil is because I had a free oil change from Honda. Intuitively, it also seemed like a good idea to do that instead of just switching straight to synthetic. I guess GAFIT feels the same but i'm sure he has a basis for it.
I don't really follow the MM because I don't think it accounts for severe service and hard driving. I try to change at 5k if possible.
Like it's been said, you will get a lot of different answers.
Wanderer
This is exactly what the MM does take into account.
Curious, at 5Kmile oil change what's the MM %?
Based on my driving I'll guess 80%. I see 5%@9Kmiles.
Mine...
- purchased in March
- 2,700 miles
- 60% on the MM
Still on factory fill, have not had to add any.
Plan on leaving oil change until this coming March
or if the MM gets to 15% prior to March.
I'll be going with the standard 0w-20 fill and a filter
change with each oil change
- 2,700 miles
- 60% on the MM
I would just go with what Honda recommends in the manual. Then change it to whatever you want afterwards. I changed mine recently to Honda 0w20, I feel it idles a little quieter and revs easier but I could be imagining it.
Manufactures are pressured by public demand and the EPA to extend oil change intervals. The buying public demands low maintenance costs and the manufactures have responded. Keep in mind that no matter what oil you choose, it still has the same amount of contaminants entering it. That is why even the best oil has to be changed eventually.
I'm only giving my educated opinion. I will admit that modern cars, and especially Honda's, will last a long time as long as you keep them wet. My maintenance schedule is for those of us that run a car HARD and expect it to go 200,000+ miles.
I don't really check the MM, so I don't know what it says at 5K. I think right now i've got like 3K on the oil change and it's around 70%. Will probably end up at like 30% when I change it.
yeah, it calculates oil degreidation based on temps, rpms, etc.
Wow, that's pretty fancy.
I'd really like to know more about exactly how this works. Guess i'll Google it lol
Here is what Honda has to say http://www.kleinhonda.com/images/maintain_honda.pdf
https://techinfo.honda.com/rjanisis/...606O00355A.pdf
1 more http://www.infineum.com/sitecollecti...a%20042109.pdf
I have yet to see any proof that the MM actually takes into account all of the factors that people theorize that it is capable of.
I ask this question to people who think it knows all. Why is there a standard and severe maintenance schedule if the MM supposedly knows the exact conditions the car is operated in?
Edit: I have seen things from owners and from dealers. Having worked at auto dealers, I don't believe anything they say. They are probably the largest source of disinformation regarding cars that exists. Out of curiosity, I'm going to see how what my percent left is at my next 5,000 mile change.
