Swift springs on coils?
That's probably why it's so bouncy.
You can order custom linear rate springs from Swift with your own specified O.D. and spring rate you could throw on your D2s. Contact Swift.
i'd be suprised if regular Swift drop springs would fit on the D2 perches.
Let us know if you do.
I hope so the guy said they're going to be 5kg springs. Just hate how my front wheels comes off the ground on bumpy highways
You could probably call D2 to get the spring length.
I tried they couldn't tell me the length and as far as rates goes on the D2s I have no idea. Going to jack it up in the morning and call swift again.
Definitely check the rebound/compression settings on the coils. Put them to full soft and drive the same road(s) where you experience the front tires lifting from the ground. I have 12kg/8kg rates on mine and for daily driving I'm running 10clicks from full soft up front and 7clicks from soft out back. On circuit it goes to 14clicks and 15clicks (fr/rr).
How are 5k springs bouncing you that much? Something seems off about this...
My old coilovers also came with Swift Springs, but they too were J's Racing N1 by Crux...with 16k/14k spring rates on a 2100 lb car.
I think he's talking about getting the 5kg springs
^^ Yeah. I called swift to see what springs I should get they said 5kg but I'm a little worried I might bottom out. Oh and ride height isn't 4inches off ground it's actually 2 1/2 lol
You contacted D2 and they couldn't tell you the spring rates that come with the suspension? I don't even see how they could set the internals up if they are not sure what rates they are using from the get go.
Hope you finally get it all sorted out.
