necessary to shift into Park before turning engine off?
#41
Funny that you should say that... if you are of the folks that "understand," then why did you not realize that shutting off an engine in gear would cause a car to "lurch" to a screeching halt? That you didn't connect the fact you were pressing the clutch in an MT, but not think about what you might need to do in an AT to "replicate" that clutch action?
#43
Just a question been a while since I've been driving a stick, but if you're parked, in gear, and get towed, and they tow lifting the back of the car, wouldn't that really ruin the transmission?
Then again, I imagine its just as bad for an AT in park.
#44
Unless the the tow operator is an idiot, they would know to hook up the drive wheels, and the car would roll on the free spinning wheels, otherwise if they do that, they're gonna be on the hook for damages. Hence why you see full time all wheel drive vehicles either flat bed towed or the drag wheels on dolly wheels.
#45
FYI, I drive both an MT and AT, know a bit about cars, take care of my cars, don't have subject-matter-expert credentials on the combustion engine nor a PhD in English. But I do know that in order to respond properly, the question must be understood and a background of perspective as a reference point helps. So please, we're just trying to help... for what it's worth to you.
Happy motoring... but not in Park, please.
#46
I wouldn't make a blanket judgement about AT drivers "understanding" when YOU are the one concievably asking questions and looking for understanding.
I trust the many posts in response have broadened your horizons of understanding?
#47
I'm new to AT. I'm used to turning off the engine as I coast the last few feet into the garage. But with the AT, I notice that when I turn off the engine with the AT in Drive, the car seems to lurch to a stop.
Why does that happen? Is it bad for the transmission? It is necessary to shift into Park before turning off the engine?
you can shift into neutral on a AT as you did with your MT car with no lurching.
navila17
05-17-2016 09:47 AM
Meobe
01-02-2015 03:26 PM
hydrogennine
09-07-2011 11:59 PM
