help!
Um... is this what you did?
(copied from the manual pdf page 83 & 84)
To turn off the Auto Door Lock modes:
1. Make sure the shift lever is in the Park (P) position (A/T vehicles).
-Neutral for you.
2. Turn the ignition switch to the ON (II) position, and open the driver's door.
3. Push and hold the front of the master door lock switch on the driver's door until you hear a click (after about 5 seconds).
4. Release the switch, and within 5 seconds, turn the ignition switch to the LOCK (0) position.
-Neutral for you.
09Fitter
01-14-2015 02:12 PM
doane2u
03-04-2013 12:52 PM
