GE8 rear fitment tips.
Okay.. so lets face it. Honda screwed us on this one.
First gen Honda Fit's had a replaceable spindle allowing a person to "shim" the bottom bolts to provide minute but valuable camber/toe adjustments.
Refer to the picture below.
Second gen Honda Fit's came with a press fitted or in other words one-piece spindle/axle beam assembly, allowing no area for shimming to provide camber/toe adjustments and in essence making wheel fitment tricky.
My question to the GE8 fitment gurus is, what crafty ways have we found to scrounge every last mm of fitment from the rear end? Cutting up axle beams? Shaved hubs? Shaved drum faces? Rolling & pulling? "Noblesse"?? Please enlighten me.
Here is my car for... reference?
It was an idea that has crossed my mind in the past but I rejected as I am in favor of the idea that the drum face is the thickness it is for a reason. But yes, the face the wheel mounts to. If you shaved material from it evenly, you could decrease the distance out that the wheel is mounted by a few valuable mm, as many as you dare. But, cracking seems inevitable especially in harsh conditions?
i neeed to find someone local with a ge ive have almost perfected the rear camber on the gd by doing modded shims behinde the hub i have to see a ge in person heres what mine looks like if you havent seen it
P1012608.jpg?t=1305604308
P1012605.jpg?t=1305604344
P1012611.jpg?t=1305604376
remember they might be shims but you still have to compensate for the toe!
@goobers, If I were to shave something I'd rather shave a 50$ drum. And uhh no? Shaving the drum or wheel does not change the offset of your wheels. What it would amount to is a more recessed mounting point for your wheel. High offset wheels are not an option to me, so lets scratch that idea right now. You can keep your 7" wide +43mm offset wheels
@nxtfit_08, As I stated in the first post, shims will not work for the GE model. P.S nice car though, how much body work did you have to do?
well something has to work for the ge thats why i want to see it for myself not that i dont trust you but just want to see for my self
also for my car did rear camber and rolled and slight pull on fenders thtats all and thanks
You immediately took the offensive just because I said to get something with positive offset. I didn't mean that shaving those parts changed the offset on the wheels, it moves the tires into the body the same way a positive offset would.
So again, instead of doing something complicated and possibly dangerous as shaving parts, you could trade those wheels for something with a positive offset... +43 and +53 aren't the only two offsets available in the universe.
That being said, I'm done with this thread.
Wahh wahh. The entire purpose of my creating this thread is to learn very specifically what methods OTHER people with LOW offset wheels have done to make their wheels fit their GE8's.
Selling your low offset wheels and buying higher offset wheels does not count as an accepted method. That falls more into the "I gave up" category.
I am now running 15"x8" +0mm offset, and last season I had 15"x8" +15mm. I am aware that there are a wide variety of offsets available, but unfortunately nothing over +20mm (assuming 8" wide) appeals to me.
That said, you run 16x7 +43 offset wheels, so you probably have no business offering advice in this thread anyways.
KTHXBAI
KTHXBAI
KTHXBAI
KTHXBAI
SO WRONG!!!^^ do to the fact that you CAN do it to the gd and "maybe" not the ge it will be figured out soon enough so bro get you facts straight before you call somebody a douche.,
my facts are straight, bro. iv aligned countless fits and 99% of them have no alignment issues in the rear. i know you can do it to the gd, but the ge has welded freakin hubs. shaving drums and drum backing plates is just retarded. oh, and i called him a douche for getting on people who are trying to help
ok well just for your info your not the only technician on this site i was the #1 alingment tech in the previous job i was just at in the entire company so i do know how to align a vehicle but im sure there has to be a way to do it even thought its welded without shaveing the hub its like drilling out holes to adjust camber or caster on the front struts. i know it welded but but makeing maybe a spacer plate or something might work. btw no real need for name calling be the grown up and give advice thats all im saying
also on that note im not i repeat not starting a arguement about this but just think about it! p.s. now i work for a sport shop!
Have not run across that change by Honda. Guess they got PO'ed by grassroots mechanics improving the Fit. But then:
How about scounging a junkyard axle to replace the one that has fixed stub? Or you could 'saw' the stub plate from the axle and replace that part. Tho the former is better but more work for you.
I have an engineer's problem with a 'press fit' on the axle stub plate to the axle plate so I wonder if its not welded.
good luck.
@mahout. I plan to do exactly that. However seeing as I am also a technician at the largest honda dealer in canada, its cheaper for me to order a brand new axle beam then it is to source one from the wrecker. Stay tuned at the end of the month.
At everyone else, I don't think anyones technical ability or knowledge was ever in question, he was just retaliating to me being a dick. Which I confess to. Quitting smoking is as hard as they say guys!
kennychang1137
18
12-06-2012 10:35 AM
