what's the skinny on Traction Control?
I tried a search. Haven't read the details in the manual yet.
Does it affect anything being turned on - drag on engine power, breaking etc?
Does it annoy drivers who already have decades of experience know how to control their vehicles in the worst of icey and turning/braking situations?
Its nice if you have a 5spd like I do, because the stock tires break loose rather easily in the rain and snow.
I've never really been a fan of ABS, or TCS, but it doesn't seem to be intrusive on the Fit at all. At least not in my daily driving.
Here's an informative explanation: Traction Control
I believe it was an option only available w/ the Navi package up till the 2010's but is now standard on the Fit.
I didn't spring for the Navi, have a 2010 MT Fit and wish it had TCS.
I've been driving cars since the early 60's and I think the TCS is a positive step in driving a car, bummed I missed it by a year on my Fit.
I stand corrected. New Fit's have VSA + TCS
So, VSA is this, an enhanced ABS system: Electronic Stability Control
yeah that stuff. I can see it's use in icey Iowa where winter is heck most of the time and look forward to it's use then, but maybe it hinders me on dry pavement turning or dragging on the engine when braking? just some thoughts.
I'm sure leaving it on all the time is the preferred use as you would NEVER have time to activate it when you are going into an uncontrollable slide. Since one doesn't know WHEN that will happen....
just wondering what, if any, cost there is mechanically having it on on a Honda Fit
It shouldn't interfere.
A couple of years ago I had to swerve drastically at highway speed to avoid a collision and when I straightened the wheels I was still sliding, I swerved back, started sliding the other way... and after a couple of oscillations got the car under control and continued... I was amazed I was able to do so (just luck)... and realized that traction control would've taken care of that for me. Because next time I might not be so lucky.
Computers drive better than we do, is what I'm saying.
~SB
If there is any problems detected with the TPMS system, you can not turn off the VSA or TC.
Example: if I want to burn rubber in 1st gear on my Automatic... if that is even possible... will shutting off the ESC/TC whatever allow that?
I left it in D and romped it, and it took off, but didn't spin. Will it ever spin the tires? Like in 1st, with ESC fully off?
i can answer that, i have a brand new 2011 ge8, and a sport auto. the answer is "no way in hell" you could stand on the the brake and gas at the same time and release the brake, and it STILL wont burn rubber, youre going to need about 50+hp to the wheels to pull that one off in an auto. now my old jetta VR6, that did it fine, but it also had a v-6 with 200hp...
If the VSA detects wheel slip, it'll kick on to eliminate it. Of course, the engine doesn't really have enough power to allow much spin anyway. If the road is wet or icy I've seen some spin. But on dry road its pretty uncommon.
Well here in Montreal, we are famous with our potholes, you can find one literally every meter... A quick example would be i am braking for a red light, normal braking, and there are tons of potholes before reaching the light, everytime the Fit goes over one, the ABS would kick in. You can hear the ABS pump pumping, and the feedback from the brake pedal.
I suspect the Fit has a 2 stage ABS system, because during winter, when i am actually skidding, the feedback is actually MUCH stronger. When i go over potholes/speedbumps it seems i only feel vibration and can hear the pump for about 1-2 seconds. Is not a big deal, is just annoying.
I think the ABS is just WAY too sensitive. I used to drive a Toyota Yaris on the exact same roads, and it never triggered the ABS on the Yaris, except in winter when it skid of course.
interesting. maybe tires rotate out of sync for part of a second as one rolls through a deeper hole... but while turning, tire sync is sensed and compensated for.
I'll try to burn the tires taking off after the pavement dies out
I actually had the traction control stall me out. My foot slipped off the clutch on a slick spot and the VSC cut the engine power and I didn't catch it quick enough and car stalled. Not a big deal in normal driving but it looks like it will cut off some shenanigans hehehe. Now that my Fit is broken in I have been looking for the corning limits of the stock tires and I can see why they put the VSC as standard. There have been a couple of times that I figured if I pushed it much harder the rear might come out. Not really an issue in the dry but in more moist conditions it could be a surprise for someone. As for as I'm concerned nothing that can't be solved with upgrading from the stock tires to something much better. It would help with keeping the ABS at bay too, because grippier tires mean less chance for lock up.
My experience has been that the GE8 has bad wheelspin issues with the manual in wet conditions. The gearing is short and the engine is responsive to inputs.
My tires are on their way out though. Yesterday I could not get traction at the top of 3rd () with a little rain on the ground, which was a new one on me for a low powered, normally aspirated 4 banger. Prior to the k&N intake, I never experienced that either, so I think the power level has been raised.
I'll do some playing around with my AT. I bet I can spin them somehow with the ESC shut off. Not BRAKE STANDS but just taking off. Shifting 1-2-3-D feels very "MANUAL" like with this car. Could be fun.
Steven Hung
01-18-2009 11:36 AM
