Rattling Noise - Please Help
Hi, i recently purchased a new base Fit with manual transmission and i noticed that sometimes when i start the car, i hear a rattlling noise coming from the engine area. Sometimes it goes away by itself after a couple of seconds, or sometimes it goes away after i step on and release the clutch. The noise sounds tinny and hollow. I also notice it sometimes when i'm driving in first and second gear. The noise occurs intermittently. I'm definitely bringing it back to the dealership next week, but i'm wondering if anyone here knows what it could be? I'm really bummed that this is happening and it makes me paranoid that i'm going to have a lot of problems with this car in the future.
What does GD stand for?
Old story, a man bought a brand new Caddy. It had a rattle, drove him nuts. Had it in and out of the dealer several times. Finally they found the problem, there was a loose nut in the door with a note on it. The note said I hope you had a hard time finding this you rich SOB!Yours will say
あなたが豊かなこちらにあなたを見つけている困難な時がすすり泣くようにしたことを希望してく ださい
JIm 0311
JIm 0311
Suggest you take a quick look under the hood before you take it back to the dealer. Maybe a missing fastener, hood prop not secured, air filter clips not on, etc. Your noise could easily be a vibration only occuring a certain rpm. Higher rpm generally means more vibration, so cold start with choke, or 1st & 2nd gear driving is when rpms higher and maybe why it is intermittent.
_
_
i have the same exact noise on my 2011 m/t sport. at first i thought it was a clutch bearing, but after listening to it more with the hood open, sounds almost like a bad pulley on the drive belt. let me know what your dealership does and if it fixes it
I couldn't get the rattling noise to happen at the dealership. They couldn't find anything that would cause the rattling noise either, so if they can't see or hear what's causing the noise, then they said there is nothing else they could do other than running the standard visual inspection and diagnostics. The car appears to be operating normally. They recommended for me to keep an eye/ear on it and if it happens more frequently, then to bring the car back in. I had a feeling that they wouldn't be able to do anything about it due to the intermittent nature of the noise. Well, at least the good news is that i haven't heard the noise in 2 days. I'm hoping that the noise was caused by something minor that will fix itself.
CptanPanic
08-30-2015 10:01 PM
panda1314
05-03-2011 08:31 AM
