how full do you fill your tank?
I have seen a few threads on hyperfilling, mostly pertaining to pre-2008 Fits and am wondering if similar techniques can be used on the current Fits?
So how much gas do you put in the tank for a fill up? Do you put in any after the first click?
I'm probably your non-traditional Fit owner. I have a 2009 Fit Sport MT that is used primarily as a mom-mobile. I have two kids, 1 year old and a 3 years old, and I have a long commute in the Wisconsin cold (snowing today!). I would love to go longer between fill-ups. The Fit was a natural upgrade from my 2001 Civic EX coupe MT, when it became apparent that a second car seat was needed
edit: and it says I'm a new member, but I've been reading your threads for awhile. Thanks to everyone who contributes great Fit information to this community.
I would not recommend hyper-filling a fuel tank these days. It's all part of the evap system which is meant to properly vent a closed fuel system. Over filling runs the risk of contaminating the charcoal canister with raw fuel this will adversely effect driveablility.
I do like malraux does.
Never checked it, but certainly less than a gallon. The second click simply 'confirms' the fill-up. I'm consistent in how I fill the tank. More concerned with being able to get good numbers to calculate MPG from than anything else.
On average, less than a quarter gallon. I don't pay much attention, but it goes pretty quick. But filling much more than that won't add much in the way of gas, while also potentially screwing up the evap system, so the only real reason I go to the second click is because some of the shut off switches are flaky.
More important info to know...
Gasoline Vapor Recovery
In order to put gasoline into a tank — either an underground
storage tank or a tank on a car — the tank has
to be able to release the vapors that are already in it.
Initially, gas stations and cars simply allowed the vapors
to escape to the outside air. As we learned more about
the toxic chemicals in these vapors, systems were
developed to capture them before they could reach the
air we breathe when we’re standing at the gas pump.storage tank or a tank on a car — the tank has
Topping off the gas tank can result in your paying for gasoline that is fed back into the station's tanks because your gas tank is full. The gas nozzle automatically clicks off when your gas tank is full. In areas of ozone nonattainment, gas station pumps are equipped with vapor recovery systems that feed back gas vapors into their tanks to prevent vapors from escaping into the air and contributing to air pollution. Any additional gas you try to pump into your tank may be drawn into the vapor line and fed back into the station’s storage tanks.
Not trying to be a wise guy BUT as others have pointed out,overfilling your fuel tank can be harmful to your vehicle.Every vehicle brings compromises. I personally do not like the fact that the Fit has drum brakes in the rear. I also do not like having to fill up so frequently,as the tank is so darn small. I accept the small fuel tank as a minor inconvenience to my otherwise fantastic vehicle.I stop fueling after the first click and find the fuel gauge to be past the F. BTW, I should say that prior to the Fit I was driving BMW's for 6 years.
Yes by topping off your gas tank you not only risk damaging your car's vapor recovery system but you also risk damaging the station's vapor recovery system. Adding more gas after the nozzle has automatically shut off can cause the station's vapor recovery system to operate improperly. This contributes to the air pollution problem and may cause the gas pump to fail to work for the next person.
No matter the vehicle I always fill the same.
Dump in fuel until the first click... wait a few seconds for the loaded fuel to settle some.
Start filling again until the second click... then I'm done.
Ok, now lets talk about how we fill our windshield washer reserve tanks.
Well I use to just fill till it clicked, but w/ gas going up in price by the minute! I'll fill er till she's FULL! I found out I can get atleast 1.5-2 gallons more in now.
I'm satisfied to stop at one click. The fuel gauge show's full, and there's no need to get really anal about it.
I think they just adjusted the nozzle shut-offs at all our local stop'n robs, for good of for ill.
There were gas stains on my bride's panzer after it overflowed before shutoff last winter, and yesterday the pump at two local convenience stations (same company) were set so sensitively that they wanted to shut off right away.
My point being there is nothing magic about the automatic fuel shutoffs; it's all dependent on adjustment, and you may or may not get exactly the same amount of fuel in the tank.
I realize the onboard may be a little optimistic, but it give accurate relative mileage.
Moon
Moon
One other thing; somewhat depending on time of day and degree of sunload, the fuel in the tanks will tend to be 'cellar temperature', just like a good mug of Guinness. However, once the fuel is in the tank, it will be much more subject to the ambient temperature, which will often be much greater than cellar temp.
This will cause the fuel to further expand, and if the tank is already full to the tippy-top, you'll have a problem with the purge canister.
Do what ya' gotta do, but I'm not seeing the advantage of stuffing another half gallon of gas in the tank. Most of us aren't crossing the Sahara with jerry cans strapped to the bumper.
As regards fuel mileage calculations, I'm not sure we're solving that problem either. Already mentioned the variability of the shutoff adjustments as regards calculations; then there is the issue of odometer reading vs actual mileage. Using our nav, all our cars are optimistic by 2-3 mph on the speedo, which makes me wonder if the odo isn't off as well.
So even if the mileage computer isn't absolutely accurate, it is relatively accurate. You can compare this tank to the last one, and that's plenty good enough for me.
Moon
Moon
Moon
Moon
An extra 100 miles? That would mean you get like 50MPG! What am I missing?
