View Poll Results: What was the outcome of your LMS recall work?
Work done without issue and engine running smoother than pre-recall
25.71%
Work done without issue and engine running the same as pre-recall
17
48.57%
Work done without issue but engine running differently, but will not take back
2.86%
Work done with either cowl, wiper, or washer problem. Engine OK.
8.57%
Work done with either cowl, wiper, or washer problem. Engine problem as well
14.29%
Voters: 35. You may not vote on this poll
Lost Motion Spring Outcome Poll
There have been a number of comments spread thoughout a number of threads commenting on the results of this recall work. This poll is an attempt to find out a rough percentage of the quality of the Honda dealer network concerning this recall.
This is my first attempt at a poll. I f I screw it up, someone please fix and post a proper poll.
I left the car overnite so engine would be cold.
I picked the car up the same time the next day. The engine
is quiet on cold startup. When hot, there is a faint ticking
which I believe is ok. The far left drivers side cowl clip is broken. I'm not taking it back...
Thanks for posting your experience hog. Was that Rick Case Honda? I had thought with all the bitching and moaning in the other threads there would be more negative feedback in this poll. Oh well.....
