AT: D mode vs paddle shifters for best mpg
Old 03-31-2011 | 05:48 PM
buckyfit's Avatar
2011 Sport AT here. I'm interested in getting the best mpg without advanced hypermiling techniques. I just try to drive conservatively (gentle acceleration/braking, top speed 65mph on freeway).
I thought that using paddle shifters in S-mode would be the better method since I could control the gear selection, reduce unnecessary shifts, and keep rpms low. But I only got 31.8 mpg on approx 75% freeway/25% local driving. The 31.8 mpg was confirmed through trip mpg gauge as well as hand calculation at fillup.
So I was thinking, would D mode possibly get better mpg than paddle shifters due to more conservative algorithm? Since the throttle is drive-by-wire, does D mode give gentler acceleration given the same gas pedal position?
Although that shouldn't make a difference at 65mph on the freeway, right? According to the real-time mpg gauge, I get 35mpg (1 tick below 40) at 65mph on flat freeway. That doesn't seem that great to me, because I got combined 35mpg on my 2001 Civic MT with 75% freeway/25% local
Old 03-31-2011 | 06:21 PM
TakeFlight's Avatar
At 60mph on flat highway the real time mpg is 40ish for me. I have about 1200 miles on my 2011 Sport. MPGs have improved over the first few fill-ups although I've also been trying to improve MPGs with my driving technique.
Old 04-05-2011 | 08:24 PM
Nukedog's Avatar
66mph / AC on / 38mpg on flat Florida highways...in D...
A 90fwhp car certainly isn'e peppy enough for these paddles..lol
Old 04-05-2011 | 09:18 PM
Tauwolf's Avatar
Just drove to Chicago this past weekend from northwest Ohio. Tires pressure at 38. Averaging between 65-70mph using control, I got 36mpg. On the way back, averaging 70-74mph and using cruise control, I got 32mpg. I admit I'm not completely happy with those numbers..... :/
Old 04-05-2011 | 11:05 PM
EvoFit's Avatar
none of these replies have anything to do with OP's topic of paddle shifter VS just leaving it in D. so far its just been a collection of people posting what they get for MPG. none of you stated if you were using the paddles or not. as for me, i have a manual so i can't really chime in. Still interested though.
Old 04-05-2011 | 11:13 PM
Tauwolf's Avatar
The OP already has his baseline for using S-Mode with paddles. I posted my D-Mode cruise contol numbers because they are similar to his D-Mode average, and I am similarly disapointed.
Old 04-06-2011 | 04:19 AM
buckyfit's Avatar
Based on Tauwolf's post, it seems that at 65 mph, it makes no difference whether it's D mode vs paddle shifters, which is what I expected since both should just be in 5th gear locked up, no difference.
My theory is still that D mode will get better city mpg than paddle shifters due to more conservative throttle response. I think I notice that in s-mode, the throttle is extremely sensitive, the slightest push, and the car will take off. Whereas in D mode, you have to modulate the throttle more.
Old 04-06-2011 | 07:35 AM
Nukedog's Avatar
Does the coast fuel cutoff turn off if in the "S" mode when using the paddle shifter option? If so then that could explain some of this.
ncoflin
09-12-2015 08:32 PM
secondspassed
10-07-2009 06:03 PM
ezduzit
03-07-2008 05:01 AM
mahout
02-22-2008 06:54 PM
sebwin
08-16-2006 09:52 AM
Quick Reply: AT: D mode vs paddle shifters for best mpg
