Wheel size question. 2011 base fit
First off. Newbie here. Not new to Hondas at all, but just needed a little toy so I bought a taffeta white lil girl. Probably old enough to be most of your fathers actually.
Looking around, and doing some reading, I believe I have found the correct answer to what I am wondering, but wanted to ask the experts. I want to change my styled steel wheels with the sweet hubcaps out for something a little prettier.
I think I wanna do a 16 X 7 wheel with a 40 offset. It seems that the size works without rubbing from what I have read. I was planning on maybe a 205/50-16 tire as well. If I have bad info will someone please chime in. I plan to just keep the stock height, but may put on some of the basic tein springs (or similiar) down the road. Would the 1 to 1.5 inch drop cause rubbing problems with the above mentioned wheels?
Thanks for the great site in advance.
Your setup mentioned will fit great with no rubbing. However will look a little silly until its lowered, but not as bad as stock looks now. So do it. If you dont plan to lower it at all step up to a 17".
kevinkidstar138
06-20-2010 08:24 PM
abcsr2ez4me
04-30-2007 07:19 PM
