please advice on wheels offsets.
hi im getting a new rim. still undecided on the size seems theres so much rubbing issues. also i will install some high-low soft-hard adjustables.
therefore please help me with this setup, in order not to have any rubbing issues.
What is the car stock rim offset?
i want the sidewall of the rubber to be aligned with the side wall of the car body.
but without rubbing.
195/50/16 - rims should be what offset? 16x??? offset ???
195/50/15 - rim should be what offset? 15x??? offset ???
i love the look on this ride by silverjazz77 guy.
https://www.fitfreak.net/forums/2nd-...r-pics-10.html
195/50/16
16x70jj offsett 44
the setup is exactly like i want.
question, will the setup be affected by different adjustables?
i want that exact look, and no rubbing.
195/50/16
16x70jj offsett 44
i got my taiwan made SSR type F 16 inch, offset 42.
wrapped with potenza andrenaline re001 205/45/16. i should have opted for 205/50/16...now my wheels seems like a 15inch...
with coilover, no rubbing even with full load (cannot see behind)...also no rubbing. front 2 finger, rear 3 finger...
im afraid that if i go lower, my front camber will be off...
with 2 finger gap at the front, i have adjusted the front camber to -0.5 both sides...
ssolty
11-25-2007 11:42 PM
