anyone USDM take their cluster out yet?
The JDM and other red clusters seem to be laid out exactly as our blue USDM clusters. The only difference I know of is the information display on some models is operated from the bottom, right-hand corner of the steering wheel... just below where the cruise control buttons are, opposite from the voice control navi button on the navigation models.
No, we don't get those luxuries in the U.S... we have to reach over the steering wheel and push a common button multiple times for our info!
Anyone please correct me if there are other differences. I investigated the same thing back in the summer and the above was all I came up with. Someone may want to ask the forum member '555sexydrive' about this... he's American but lives in Japan right now, and has a kickin' Fit... he's pretty knowledgeable.
Also, if the lights behind the cluster would accept LEDs (I think they're just standard bulbs) I don't see why they wouldn't work. Problem is, I think some of the red letters/etc. on the red clusters are actually painted red or have red colored plastic behind them. I could be wrong about this too.
You can check out quite a few of the red clusters on YouTube. People have done vids at night showing their dashes.
If anyone finds anything else, please post it... I will do the same. Personally, I'm not thrilled about the red cluster... I think our blue USDM clusters look great... but the red may be nice for an occasional change.
BTW, I don't remember the exact price, but I do remember replacing the cluster is almost astronomical... considering it is just a cluster.
Gauges are back lit by LEDs that are attached to a circuit board, like in the pics below. Swapping them will require taking apart the cluster and re-soldering on replacement LEDS.
You can see a freshly changed one (yellow square) in this swap on a BMW:
It's doable!
It's doable!
I mean, I can see the above two examples are definitely LEDs... and that sucks for maintenance reasons. BTW, isn't that first image from a Scion? Now you have my curiosity up about the Fit cluster.
Man, what does Honda expect if a dash light burns out? Hire an electronics tech or replace the entire flippin' cluster? At the price of techs and replacing the cluster that's an absolutely ridiculous option.
First drop the steering wheel all the way down and away from the dash. Then pry apart the cover where it meets the dash, near the bottom of of the dash. Once it's apart then lift the entire cover up and away, just be sure to unplug the mirror switch before you fully pull the cover away. Then there's just 4 phillips-head screws to remove, 2 at the bottom edges of the cluster and 2 at the top. Once those are out pull the cluster out and unplug the 1 plug near the top of the cluster. The clear plastic is then removed by carefully unclipping it from the assembly.
Replace the cluster in the reverse order, and having a magnetic-tip screwdriver REALLY comes in handy. Trust me on that one.
Again... that sucks! On top of that, I now know at least one Honda tech at the dealership I purchased mine from who doesn't know what he's talking about!
BMW cluster changed from red to blue... looks kinds' nice, actually.
YouTube - BMW E46 blue led cluster
At least you know it can be done.
Check out some of the other vids while you're at it.
oh def can be done, but i don't have the know how to tinker with leds, nor do i feel like breaking the cluster apart.
not sure why the bimmer dude wanted blue, i rather dig the red dash. to each their own.
I'm in the exact same boat.. I really want the red interior like the JDM fit or just the Civic Si's.. Especially since I have a red Fit. I just don't want to eff things up. Might end up with purple...
mikeGe82012
01-05-2016 04:31 PM
gold-civic
05-15-2013 08:22 AM
Jamy
18
02-27-2012 12:56 AM
