Lowering my car blew my Tranny?
Old 02-05-2011 | 07:27 PM
ajinomoto's Avatar
Originally Posted by Iamnotkento
Lol. Just fyi guys, the color of the fluid does not tell anything. it doesn't mean your oil is dead.
The color of a transmission's lubricant tells a HUGE story. Transmission lubricant (regardless of whether it is motor oil, gear oil, or ATF) should never become dark/black. If it does there is a problem. You can bet on it.
Old 02-05-2011 | 08:22 PM
raytseng's Avatar
Originally Posted by ajinomoto
Something is wrong with your transmission.
ATF should NOT be black at 15,000 miles. I'm not a Honda service tech, but I was the engineering manager for five years at the company that does AT remanufacturing for American Honda and I've learned a thing or two about their automatics.
Or something is wrong with honda choice of putting in z1. it's a 20 year old spec and honda has already given that product its funeral.
Old 02-05-2011 | 08:24 PM
wontfit's Avatar
had a buddy with a huyndai tiburon, he installed brake rotor cooling vents in the rear of the body for looks only, he didn't race. his tranny went and the dealer told him the same thing, so he took it home, removed the vents (bondo'd into the body). took it back to the dealer, and the dumbasses replaced his tranny. dope? yes'm :/
Old 02-05-2011 | 08:28 PM
raytseng's Avatar
Right on the other lubes. I disagree on the motor oil. If you are changing motor oil based on color, you are throwing good oil away.
Old 02-05-2011 | 09:06 PM
ajinomoto's Avatar
I said transmission lubricant.
I didn't mention motor oil, did I? Wait, I DID mention motor oil, only because it is used in some companies' manual transmissions instead of 80/90W gear oil.
Of course motor oil, in an internal combustion engine, turns dark soon yet still works fine.
Old 02-05-2011 | 09:07 PM
ajinomoto's Avatar
The Japanese engineers from ATJ and Honda Transmission Manufacturing that I worked with would disagree with you.
Kevin Evans
06-07-2017 08:43 PM
Press Fit
08-08-2015 02:30 PM
Fitcious
10-06-2009 02:57 AM
sbualuba
09-14-2009 03:51 PM
geeq
12-12-2006 07:55 PM
Quick Reply: Lowering my car blew my Tranny?
