Noobie question....keys
This might have already been discussed here, but i can't find it. picked up an 09 Fit sport yesterday, great car in great shape, but no owners manual (the dealer has ordered one...a gmc dealer) and no second key.
Since i'm waiting on the owners manual to arrive, what is the deal with having a second key made?? i went to our local locksmith and he couldn't do it because it has a chip implanted in it....do i have to go to a dealer to have it done.
thanks
thanks
thanks
thanks
Look to spend $100+ at the dealer for blank, cutting and programming. Some newer luxury cars cost up to three times that much. The chip was supposedly mandated by German car insurance companies and has become universal world-wide.
thanks
thanks
If I am in your shoes and the previous owner kept the spare key or say it was "lost" and may find it later who knows, I will buy a steering wheel lock in case someone found the lost key, locate where you live or work and drive away your car.. I am too paranoid and that's the way I am.. sorry, I can't help it
But, if I had bought my Fit used, the first I would've done would've been to look into how much it would cost to replace the key cylinder so that they couldn't possibly use the key if they "found it" (or worse, made a copy with this intention to begin with).
It wouldn't be cheap... but better than them driving off in it long enough "sell" it to someone else (at worse) or simply better than them getting access to the car and taking whatever I might've left inside.
I'm really not worried about the previous owner locating the car...i live in central pa area, they were from new jersey. i just want an extra set...just in case i loose this set...maybe i'm being paranoid that way too. next time i'm at the local dealer, i'll ask what it would cost for a new set..i just thought there might be a lower cost alternative than going to the dealer for a new set
As customs officials at the border are not friendly towards the smell of illicit drugs in your car, I do not want to be stripped search or pat downs ( I do not enjoy pat downs as some people does) each time I drive across the border just because the drug sniffing dogs are targetting my car each time without fail and no amount of vacumming or washing can get rid of the smell.
You'll still need the key programed at a dealer though. Sure you can get the unlock working, but not the car starting.
You will do neither with a blank. Find the cheapest source for the blank and then go to any Honda dealer with your car and original key and they will cut and program the key blank.
Umm, isn't that what I said, that you have to go to a dealer for cutting and programing?
This is scary. What happened if I need to change the remote battery in the future when it is running low? how do I do it in such a way to not trigger the security mode of the car?
I dunno, I doubt very much that Honda would allow you to get locked out of your own car, just because you changed the battery.
I'm not sure under what circumstances nukeme is talking about, but if your battery is dead, it would make sense that the ignition cut off won't allow the car to start until the "alarm" is turned off. but that's assuming it has an alarm based ignition cut off... which I wonder, since the system should only have the immobilizer (wholly dependent on a battery-less chip) and keyless for just keyless (and panic). And the immobilizer only needs the chip in the key to be in the right position when you try to start the car.
edit... oh, and if I'm not mistaken, the alarm would turn itself off once the key turns in the ignition anyway.
I figured that the key operated off of either an RIFD chip that responded to a signal from the ignition switch or something in the ignition completed a circuit with the key, but after my experience I think there might just be a low power transmitter for the security system.
My ex's car wouldn't start one day and she called me for help - on a hunch I swapped my fob battery for hers, and voila! her car started right up. So she got a new battery and I put mine back into my key...upside down. That's when I tried to start my Fit and got the little flashing key light on the console and it didn't start. I flipped the battery, put the key in the ignition and turned it, then the alarm went off! Took the key out, hit the alarm button to turn it off, put the key back in the ignition and started it right up no problem. I'm assuming there's some sort of "handshake" when you change the battery.
so, then that begs the question... does the "alarm" disable when you turn the key? if so, then there might be two stages, on triggers when it isn't blaring... and one disables it when it is.
The battery has nothing to do with the Car starting as the chip in the keys are RFID. also, I don't believe that the fit's security system has a starter disable, just simply door sensors and a loud (ok... dinky) horn that sounds when a door is opened. The only thing you should likely have to deal with (with a dead remote battery) is the alarm going off; after manually unlocking the door and before turning the key in the ignition. Everything else should be accessible manually.
~SB
~SB
