Heated Mirrors in Canada cost $70 each
Old 12-28-2010 | 11:54 AM
Black3sr's Avatar
plus tax. I just called my dealer.
Wiring should be easy as they operated off same switch as rear window defog.
Old 12-28-2010 | 12:09 PM
jcuecker's Avatar
Is this in CAD or USD? Also is this for the entire mirror and housing? Does it have a winker? Is this a power folding mirror?
Thanks!
Old 12-28-2010 | 01:40 PM
milanojazz's Avatar
yes more info please, these things are a necessity
Old 12-28-2010 | 02:45 PM
Black3sr's Avatar
Cdn dollars + HST (13%)
Glass only. When I had mine apart to add the winkers covers there were two wires coming from a built in/attached heating element on the back of the glass.
As far as wiring I am assuming they attach to the rear window defogger wiring as both operate off the same switch.
Old 12-28-2010 | 05:28 PM
neil patrick harris's Avatar
IIRC, a US member here said that the insight's heated mirrors would work on our FITs. i'm not certain if he was speaking of the mirror (glass) or the entire housing.
Old 12-28-2010 | 10:54 PM
FITMugen's Avatar
Yes, 09-11 Honda Insight heated side mirrors will work with 09-11 Honda Fit. However, mirror holder is a little bit different. You have to reuse Honda Fit mirror holder. Otherwise, you have to order heated side mirrors for Canadian.
Heated side mirrors are just 2 wire connection to rear defogger.
Old 12-30-2010 | 01:14 AM
jnesselroad's Avatar
website where we can pick a set up?
Old 12-30-2010 | 07:01 AM
Black3sr's Avatar
College Hills Honda Parts
Can't tell if those are heated or not. Would likely need the harness as well.
The whole mirror looks to be $200+. I wonder if we have wiring for winkers built in? I doubt it.
seedee
05-24-2016 11:12 AM
ncoflin
07-27-2015 11:34 AM
david223
08-15-2013 12:30 PM
NewFitGuy09
18
10-01-2012 09:01 PM
YeeFit
04-03-2008 03:30 PM
