Traction control...retrofit to 2010 Fit Sport?
you could put it, but it'll be expensive and time consuming. might be cheaper to trade-in the current fit to get a new one with TC (if you can get a good deal).
speaking of snow... trying to drive earlier was fun... rip roared, slip and slide.
lol im in illinois to i dont know why it says midwest but luckily i havent driven when it was snowing outside. is it hard to drive in the winter
i still havent experienced driving manual in the snow. I said that cause i purchased mine in november! i should have waited
I'll refer you to two previous threads on this topic:
https://www.fitfreak.net/forums/2nd-...d-oem-vsa.html
https://www.fitfreak.net/forums/2nd-...ssist-vsa.html
You'd need the following:
VSA modulator (~$800)
Steering angle sensor
Yaw sensor
Possibly a new ECU and harnesses
As such, it's probably not worth trying to retrofit it unless you happen to find a scrapped car and can get the parts cheap...
Yaw sensor
I drive a semi with traction control and I say it dont work. Any time 1 inch of snow and you get stuck in a dock its a waste of resources. I turned it off and got out no problem. What happens is when the wheel spins it applies the brakes stopping any forward movement which could cause you spin out if moving at highway speeds.
My wife's car has AWD traction control and stability control... The owners manual says to turn off the stability control when driving on loose surfaces because it confuses the traction control..... I have seen a Z-71 pickup with 4WD engaged and the gas pedal on the floor pull a small tractor with the back wheels almost to to the axles in sand and the disk plow almost buried in sand with out breaking the tires loose..... I thought it was stupid that the gas pedal had to be on the floor to over come the automatic application of the brakes that was being applied by the traction control... The stability control on the same truck scared the shit out of me when it was activated on a back road one night and took over control of the damned thing and had it up on 2 wheels....
I had the same problem with my Grand AM GT in the winter, the TCS was more of a problem then a help in snow and slippery conditions. Just think though all cars will have to have a TCS in 2012
edit: im sorry im actually wrong its ESC (electronic stability control) that will be required by 2012.
I guess that trial lawyers must have something to do with all of this stupid safety legislation... Just think about how much money they can make suing auto manufacturers when someone dies in an accident because some safety feature that was supposed to save some dumb ass that killed someone or their self in an accident that could have been avoided.... Also consider the money that the mass of lawyers that the auto manufacturers get paid when fighting the same lawsuits..... I like cars that are devoid of all of the high tech features except for those that make the car perform better and last longer, but are still a pleasure to drive..... A car that is properly designed the size of a Fit without all of the extraneous crap would cost less, weigh a hell of a lot less, handle better, go faster, be cheaper to maintain, and get better fuel mileage.... I never thought I would ever see a 1500cc engine powered car with power steering and brakes, cruise control and power windows... The electrical trouble shooting manual for the 2007 model has 204 pages and they keep adding more crap than any mechanic can possibly keep up with the service procedures to keep one running and operating properly.... I do have a weakness for power windows, seats and air conditioning but items like that and the others mentioned above should be optional.
I agree. If you have a loss of traction with a Fit (or any car), it's easily remedied with less throttle. It's just that simple. I think a LSD option would be a better aid to deter traction loss than the current traction control system.
ABS and traction/yaw/stability control are better than a driver when the unexpected happens... and they save lives.
In certain situations or on a track, some drivers MAY be able to do better. Then again, professional race car drivers sometimes leave 4 black streaks on the pavement before hitting a wall, meaning they were in full lockup and not performing expert threshold braking, and that in a situation where they know every nuance of the road surface and layout.
People die every year in rollover accidents which start with the vehicle sliding sideways. Many people also die trying to avoid hazards in the road including live animals, overcorrecting into oversteer, and driving into oncoming traffic or off the road.
I've had some drivers training as well as autocrossing and road racing experience, and can theshold brake or control lift-throtle oversteer on those situations. I've also been in on-street situations where I've panic-braked or overcorrected in an emergency maneuver, and I guarantee that the average driving public is much less familiar with vehicle dynamics than I am. Defeatable (and preferrably adjustable) traction/yaw control should be mandatory on every vehicle.
I can honestly say I have NEVER been in a situation where I said "OMG I wish I had traction control!" Most accidents are form people driving to fast for the conditions or not paying attention. In the winter months I will see more SUVs and AWD cars in the ditch then any other car, why? thats because these people think having AWD or a bigger vehicle they can drive as fast as they want. ESC will only give people more of a false security and will pay even less attention to driving and drive more recklessly, because ESC will save them from any situation.
On performance cars the ecu cuts power to the wheels to control traction and most are four wheel drive and that different than whats is vehicles now. If your racing your not distracted and the ecu is tuned for max speed with out losing traction. Thats different than the brakes being applied and causing a spin out.
ABS works amazingly well... To me having the government legislate safety requirements that responsible consumers may never benefit from and give an excuse to those less responsible to feel invulnerable is rewarding the irresponsible.....
